My gauge cluster is tripping out a bit..
Everything in the cluster is fine with the exception of the BRAKE LINING light which illuminates as it wishes and the temp gauge which will be indicating that I am at operating temperature, then at random it will jump up to 3/4. Both glitches are independent of eachother (they can happen separately or together) and they can be fixed for a few minutes by tapping on the face of the cluster.
What can you guys tell me about this? Is this the batteries needing replacement or is this a sign that the whole SI board needs replacement?
What are your recommendations on fixing it? I am no stranger to ripping clusters apart and reparing electronics if it is something that can be repaired with some solder or wires.
I am planning on just pulling the bulb for the BRAKE LINING light.
Thoughts?
PS. I am not sure if it has any relation or merit, though I have noticed that when i shut my car off , the tach jumps up a few hundred rpm about 4 seconds after the car is off. I thought I would mention it in case there is some relation.
>I searched some more and found this: http://www.s14.net/forums/showthread.php?t=38562&page=2
which says the gauge "dancing" can be caused by bad wiring on the temp sender or a bad ground on the back of the cluster, though mine can be fixed via tapping so it doesnt seem that it would be the wiring in the engine bay.
>This also: http://www.m42club.com/forums/showthread.php?t=7086
Someone commented on tightening a nut on the back of the cluster (presumably part of a printed circuit that is held on by a nut)
Thoughts?
