Car, 89 Cab....
bunch of stereo noobie questions...
Ok, so I got a Precision Power a1200/4 amp....
the instructions say run a 4ga ground back to the battery,
Doesn't that require a second hole to be drilled, not fond of drilling more holes in the firewall.
Can I buy a grounding block and ground it in the trunk somewhere? I guess I will need to sand off some paint to get proper ground, correct?
Also, I have a set of Monster wires with the external ground wires, these ground to the source, is somewhere better than others to tie to source, or use the source ground wire? SHould I run a seperate, smaller gauge ground to the battery for that too?
Can I run the ground wire beside the power wire?
I plan on running the power wires on the passenger side and the patch and speaker wires down the drivers side...
Everything will run to trunk where the PPI amp and PPI speaker crossovers are and I will then run wires back out to each speaker from here...
The amp and cross overs take the entire rear seat back area of the trunk, is it is bad to use Monster Right angle RCA adapters to gain more clearance?
Is it bad to mount the crossovers on the powerside of the amp, my thinking tells me it is?
Thanks and sorry for the barrage but I don't want to fuck this up...
