cd43, what do I need to get it work?
  • cro320
    • 147
    Hi
    what do I need to get Bussines CD43 running in my E30?
  • StereoInstaller1
    GAS
    • 22679
    A wiring harness and an antenna adapter
    Closing SOON!
    Thanks for 10 years of fun!
    • ///M-TRD3
      • Jan 2006
      • 179
      ^ Is this a generic harness/adapter that you can get at any stereo installation shop when doing the install, or something particular that I would need to order/purchase to take with me prior to the install?
      T.I.A.
      Einige Autos dürfen nicht runter gehen... einfach weil sie so spezial sind. - Wenn man von BMW's der '70 und '80 Jahre redet.
      • StereoInstaller1
        GAS
        • 22679
        Now, get this: it does not have the pin necessary to make an IPod interface work, so if you plan on using an iPod with it, grab the harness at a junkyard.
        GL!
        Luke
        Closing SOON!
        • ///M-TRD3
          • Jan 2006
          • 179
          ^Wow Thanks Luke, that was fast. I did not have plans to run an iPod but maybe should not rule it out by installing the adapter that does not allow it. What do you mean by "Grab the harness at a junkyard"?
          Also, I read some others threads that came up during my search and I noticed when people asked about the proper harness to use they specified the year and model of their car. Not sure why this is but thought it will be best I guess to include that my car is a 1990 325i, no tweeters, so I assume no amp (will check when I get home). Also I am in Canada if that makes any difference, as I noticed some people specified US spec or not.
          Thanks again.
          • charlescho
            • 515
            Thanks again.
            I can answer for luke on this one :)
            it depends on if you have the speaker fader or not as the harness (if getting from the dealership) come in two different versions
            they charge an arm and a leg though, think like 70 dollars
            also, I can sell you the one luke linked you to if you are interested. its brand new (came with my CD43) so let me know if you!
            • ///M-TRD3
              • Jan 2006
              • 179
              ^ Thanks Charles. I will PM you regarding the harness. Only problem for me is I bought the car and it had a aftermarket deck in it already so how can I find out if I "had" the speaker fader or not?
              T.I.A.
              • StereoInstaller1
                GAS
                • 22679
                T.I.A.
                If it already has aftermarket, no worries on the BMW harness, get the aftermarket one unless you plan on an iPod box with it.
                Closing SOON!
                • ///M-TRD3
                  • Jan 2006
                  • 179
                  ^ Thanks. Ya it has a Sony (I think) tape deck in it at the moment. I want to remove it and install the OEM CD43 unit I have. So I guess it doesn't matter which of the two different harness' I get to make the CD43 compatible? Thanks, sorry for the confusion, I am terrible with wiring or car audio issues.
                  • StereoInstaller1
                    GAS
                    • 22679
                    I would go find a pigtaill in the junkyard from E36/E34 or whatever, anything between 1995 and 2001 should work.
                    You will need the CD changer cable too. Yes, all the way to the trunk.
                    Closing SOON!
                    • StereoInstaller1
                      GAS
                      • 22679
                      BTW: if my PM made perfect sense to you, please post it up here.
                      Closing SOON!
                      • charlescho
                        • 515
                        this :D
                        • bmw325csi
                          • May 2007
                          • 4045
                          where can one get the cd changer cable, is that what i need to run a dice ipod interface?
                          harry/harout
                          • ///M-TRD3
                            • Jan 2006
                            • 179
                            Ya it did help alot, thanks. Here it is:
                            "OK: IF you plan on running only the deck with no iPod interface or auxiliary input (meaning newer than '95 CD43 too) feel free to use the aftermarket cable.
                            IF you are gonna add the ipod/aux input, go to the junkyard and find an E36 (or whatever) newer than 1996 to grab your harness from.
                            Chop off at least 8" of the decks wiring (called a pigtail in laymans terms) AND grab the CD changer cable from the trunk forward.
                            I hope that explains it better."
                            I'm going to go to the wrecker next week, hopefully a late model E36 is in the yard with the deck in it. Take it out and chop off atleast 8 inches of the wiring behind it and take that with you along with a CD Changer cable if it's still there.
                            Is there any other car it can be taken out of (Ie. Early E39 or any E38) if there are no E36's in the yard? or only late model E36?
                            Thanks Again :up:
                            • StereoInstaller1
                              GAS
                              • 22679
                              GIANT NOTE: THAT PART IS WRONG!!!
                              You need a BHO-8590
                              The part listed above is the "car side", meaning if you were installing an aftermarket deck in an E34, for example.
                              Closing SOON!
