score at work!!!, anyone know anything about this equipment?
  • DanGillan
    • Mar 2004
    • 4061
    we got a parts car in at work, and i got to take what i wanted, well i opened the trunk to see the "wall o' amps" and knew it had a good system. so i took everything except the RCA's from the deck to the amps and the speaker wire. it's 2 amps and all the little power wire shits all mounted to a piece of plywood covered with carpet, not too shabby. Here's the list of equipment (pics at the bottom):
    -Coustic U Power Logic (AMP 160u 35 watts) small one, was used to power basspump.
    -Coustic Power Logic Component (AMP 268 4x45 watts RMS) big one, used to power front and rear speakers
    - 2x Rockford Fosgate "The Punch" 4 ohm speakers. were used in rear.
    - 2x Infinity Reference 502i. used in front.
    - Design Reference DR-328 BassPump. wierd ported enclosure with two 8 inch subs firing toward eachother, PO had it set up so that the enclosure was bolted up to the rear shelf and fired through a hole he drilled in the metal and the shelf covered by a speaker grill. looks ghetto, but might be sweet with two new 8 inch subs in that enclosure mounted the same way.
    anyone konw anything about this equipment? is it any good. im gonna use it either way, but i want to know what i have. also, any suggestions as to how i should set it up? im thinking of just copying the way it was, but any suggestions are always appreciated. now on to the pics....
    thanks in advance guys for any help!!!
    Dan
  • DEV0 E30
    • Oct 2004
    • 8904
    Infinity is a pretty good brand for being @ a lower price. Those look like an older generation by a few years. Some of that stuff even if outdated is still nice for FREE. Hell even if you sold some of that stuff - nice going. :D
    • kencopperwheat
      King of Kegstands
      • 14396
      The Rockford Fosgate plate speakers are probably the best quality thing out of the lot. But if you're not running any amps in your car now, I'd slap them in there.
      Originally posted by Gruelius
      • BMWTurbo
        • Dec 2004
        • 13
        Amps will sound okay, as mentioned not super high quality, but have used them in systems before and they are fine, unless you are looknig to compete in SQ. They are a low/mid budget range of equipment over here (Australia), distrubted by Eurovox, who do a lot of OEM equipment.
        Silver Amp is one of the first generation, the darker coloured 4-channel amp is a newer model and supposedly slightly superior to the silver series...
        The sub's/enclosure is a bass pump, you mount this in the rear deck with the port firing into the cabin space, it acts as a loaded Infinite baffle style arrangement using the boot space as it's enclosure, again a compromise, but very space efficient.
        I can't really comment on the plates or other speakers, but they 'should' sound fine :)
        E30 BMW + 2JZGTE
        www.cardomain.com/id/BMWTurbo
        • trent
          YAy you got a bunch of crap
          • DanGillan
            • Mar 2004
            • 4061
            pretty much, ill use it eventually
            Dan
            • BMW BMXER
              • 2325
              Interesting thing.
              Sold it.
