diy guide to installing a 2nd trunk light
  • iwantspeed
    • 3164
    Hey guys
    I have added a second trunk light to my e30.
    I just wanted to document it and share it with you guys.
    Tools needed
    soda or beer
    scissors
    lighter
    heat shrink tubing
    needle nose pliers
    rubber band
    solder
    block of wood (not necessary)
    work area
    -(table with a cardboard box to make it easier to hold the wires)
    Soldering iron
    wet cleaning pad
    tape up the area around the lights to avoid scratching your paint.
    next acquire a complete 2nd trunk light with the full wiring harness.
    next lay the harness out and pick what you want to keep
    Then identify what does what, and know what you want to do.
    I want to have a ground wire and a power wire.
    I want to tap both wires from the existing trunk light.
    remove the red positive power wire for now.
    cut accordingly
    your left with this
    strip the ends and leave 1/4 of wire exposed
    get a heat shrink tube ready.
    twist the ends together.
    slip on heatshrink tubing
    and twist and tie the ends together
    tin the tip of your sodering iron
    heat the joint up then add soder
    strong joint
    heatshrink tubing
    heat it up
    shrinked
    tubing covered up onto the heatshrink tubing
    ziptie the wiring together to keep it neat and tidy
    crimp connectors onto the end.
    I identified which wire was which, the brown ground,negative wire I added a black ziptie to the tip to make sure there wasn't confusion.
    trim some of the shielding on the red power wire to make sure you have enough room to use the T tap
    tapped the ground and the power wire
    put the wires in the 2nd trunk light opening,
    feed them to the left side opening
    Make your connections
    brown - brown(ziptie)
    red - red
    super easy
    leave the lights out
    plug the battery back in and test to see if the lights light up.
    push the circuit pin to see if they lights turn off.
    Un plug the battery again
    ( you don't have to but I did anyway)
    remove the blue tape and carefully reinstall the lights
    Project
    Parts for Sale
    Feedback
    YouTube Channel
  • ak-
    • 12422
    Thank you for sharing!
    1991 325iS turbo
    • BeirBrennerE30
      • 2740
      Nice setup... I like it.
      e30sport.net
      '06 M3 Competition - 6-speed
      '97 Range Rover Vitesse
      • E30Nova
        • 1546
        I like that you decided to solder the wires...and then proceeded to use those shitty ass tap/splice things. ;)
        Still, way better than my soldering skills, and it looks great.
        Does it actually make a difference? I was thinking of getting some led bulbs to see if that would help. That one bulb sucks at lighting up the trunk, especially when you're putting something in/taking something out so you block 95% of the light. :roll:
        Definitely a stupid place for the lights.
        Matt
        Matt
        I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
        Originally posted by kronus
        try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
        This is like a reverse build thread; it starts out nice and gets shitty.
        • iwantspeed
          • 3164
          I soldered the wire connectors and I soldered the wires directly on me other e30 and I didn't want to do that this time around.
          agreed shitty place for lights.
          It does make a difference in cool points.
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • E30Nova
            • 1546
            So what was the need for disconnecting the battery? Just out of curiosity.
            Matt
            Matt
            • iwantspeed
              • 3164
              Matt
              figured it was good practice.
              the trunk light positive wire is a constant 12 v source.
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • bzboardz
                • 1096
                this is the proper way to do a DIY...nice pics!
                • iwantspeed
                  • 3164
                  thanks
                  hopefully its stickyness worthy
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • BDSax
                    Junkyard King
                    • Mar 2006
                    • 3594
                    why have 2 when you can have 4
                    • Atreus
                      • 1846
                      wat just happened.
                      and very cool write up!
                      1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                      1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                      1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                      1991 325iC - Calypsorot Metallic
                      1994 540i - Granitsilber
                      Originally posted by scabzzzz
                      I've had blunts cock in my mouth, but I'm not gay.
                      • cobraken
                        • Oct 2004
                        • 674
                        Did you mount two lights under the back dash? If so thats a great idea! Its so dark back there at night.
                        Randall Racing and Engineering
                        Acworth, Georgia, 30101
                        http://www.facebook.com/RandallRacingandEngineering
                        • BDSax
                          Junkyard King
                          • Mar 2006
                          • 3594
                          yes
                          • thebutcher37
                            • 2877
                            sickness!
                            I already have two lights with some bright ass LED's... and it lights up enough, but Im thinking the extra two under the back shelf would be awesome.
                            Transaction Feedback
                            • BDSax
                              Junkyard King
                              • Mar 2006
                              • 3594
                              it is awesome, thats why i did it.
                              i did it when the glass was removed, was alot easier
