My Luke box install
    My Luke box install
    So last week in a exhaustion fueled rant on an unrelated thread I confessed that I had neglected my e30 by not finishing the audio install, and had done absolutely nothing with the finely crafted instrument of musical goodness, known on this forum as a "Luke box", since it had arrived many moons ago.
    Shamed by my public confession, I got to work. I still don't have a lot of spare time, so I don't know when I can fabricate my tuck and roll covered, neon and chrome accented, windowed, cover panel,
    so I painted the back of the box black to make its appearance more respectable in the trunk in the meantime.
    I am using some old-school Hifonics amps: a 4 channel Gemini for the fronts, using the onboard crossover, and a 2 channel Odin for the sub.
    After much agonizing over the placement, as it doesn't seem like HiFonics ever meant for these two amps to be placed side by side, I went with the arrangement pictured here. The short power leads were the deciding factor.
    Inspired by another forum member who was worried about having to remove the box, I decided to make my connections to the amps as modular as possible, so (relatively) quick disconnect and removal was possible. I had a couple of cheap distribution blocks laying around so i put them to work. Those of you who have done this before can already see a problem.
    The main power wire is fused near the battery with one 70 amp fuse, however, the two amps draw different - the gemini at 40 and the Odin at 30. One big ass fuse isn't going to protect much. Luckily I figured that out before I installed.
    Here it all is installed in the trunk with the amps individually fused. Still not hooked up, as the fuses are not correct.
    Next up, run remote power and the front speaker lines for the new amps, and install the sub fader and antenna switch in the dash. Oh, and get fuses.
    Edit:
    Had some trouble getting the box to fit with the carpet, at all. Seemed to be 1/2 inch too tall. It fit without the carpet, though. On the 318 there is no sound proofing on the sheetmetal. However, there was some 5/8" padding sewn into the bottom of the carpet. Using a razor, I cut the retaining fabric on the back of the carpet and pulled the pad out, and voila, the box slid firmly into place on the carpet.
    Looks good. Glad to see this install instead of some of the fucking hack jobs around. Play it loud and have fun, enjoy!
    -Andy
      Update: Installed proper fuses and remote power line to the trunk. Installed antenna power switch (window circuit breaker), and sub amp fader, in the dash above the radio.
      Pics to follow.
      Turned stereo on, and ...nothing. No glorious bass notes filling the cabin. Crap. Need to check my connections, because it couldn't be the 24 yr old amp...
        Maybe it's the fact that you have your rca cables going from the amp...to the amp. ;)
        Matt
        Matt
        I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
        Originally posted by kronus
        try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
        This is like a reverse build thread; it starts out nice and gets shitty.
          LOL, Shoot, that is the one for the fronts, it isn't even hooked up yet. I am still running the main speakers off the deck. I need to take the dash apart to get to the front left, so that will have to wait.
          The sub amp is the one on the right. The connection sparked when I completed the circuit, so it could be anything at this point.
          Is that 5 channel PPI still on sale?
          Edit* Yep. Hmmmm.
            I often use my ipod with 3.5mm to rca plug and my 12v drill battery to bench test my amps. Good way to rule out a blown amp before spending hours designing and installing amp rack and such. I've found many head units and eq's to be junk by testing with a known good audio source. I also use circut breakers. Much easier to use on older systems and relatively cheap.
            www.gecoils.com
              OMFG: actually BENCH TEST? WTF, you mean like BEFORE installing?
              Holy shit, there is an idea!
              Just giving you some4 shit, Joe. The work does look pretty nice. And yes, that 5 channel is still on Sonic. $200, but you pretty much gotta have a DVC woof.
              Closing SOON!
              Thanks for 10 years of fun!
                What I wanna know is what do your buddies say about the box...? No one ever mentions comments from their buddies.
                Closing SOON!
                  LOL, I deserve it. My usual method is to hook it all up in a jumble of wires in the trunk and drive around until something shorts out or I get around to finishing the job. This time was going to be different. I am older, I had most of the right tools, everything was new except the amp...
                  That should have been a clue.
                  Actually, I hadn't thought of the ipod and 1/8 to rca bit. Doh! That was one of the biggest hurdles to testing without a bench, a good source.
                  I was planning on bi-amping the fronts, and the PPI is a 5-channel, amp, why would I need a DVC? Or would that PPI turn that coustic sub to dust?
                    Aaaack. I can't show it to the buddies until it is working.
                    No point in asking for the "does it do anything besides make you slower" comments.
                      The only time I give anyone a ride is when they're too drunk to drive home. Frankly, I don't feel like making their head thump/gut explode when they're in that state.
                        I enjoyed reading this thread. thanks for the lols.
                        http://instagram.com/dslovn.drives
                          I am also working on my Luke box install. Old ADS amps with new MB quartz sub. Pics coming soon... The new box is going to be great compared to the old crap that was in the trunk.
                            My friend said he didn't notice it...but he's black, so maybe he wants trunk rattling bass and 2 15" subs?
                            Matt
                            Matt
                              So I hooked up the USX 2080 in place of the odin, tightened down the connections and then...nothing.
                              Then I rechecked the connections and found the signal from the HU plugged into the wrong set of connections on the amp.
                              Turned the head unit back on and wow. Just. Wow.
                              That Coustic is playing way above its humble origins. Can't imagine what a "good" sub would sound like.
                              Scosche generic amp controller knob mounted in one of the blanks above the radio and working like a champ.
                              Its a good day.
