So, I just replaced my wiring harness, and I'm getting no power to just about everything.
I traced power (with a check light) from the battery to the starter and the alternator, but there's no power anywhere else.
I've checked fuse number 10 and the coil, they don't have any power.
The only thing I've left unplugged are the wires off the harness in the glove box, next to the ECU.
Any ideas?
Edit: Like most of these things, I spend 36 hours looking for an answer, then I finally break down and write for help, and it's something idiotic.
Delete please, or let this serve as a reminder to check your line from the power distribution box to the starter, I just thought it was worse because I swapped wiring harnesses.
Any ideas?
