Just an install of a door pod
  • reelop19
    • Jan 2010
    • 770
    I've had several requests for pictures of the back of my pods, how they install, and how the components fit in them installed. So here's a few pics of a passenger side pod getting installed. Its the version with the closed of map pocket which I prefer because I can mount my crossover in it. Enjoy :)
    I'm installing an Elemental Designs 6.5" component setup and using a rockford fosgate grille because it looked better.
    Here you can see the back with the crossover installed (I used double sided 3m tape).
    Here you can see where I've put some wire connectors (from the amp) in the door which connect to wires that go to the crossover.
    BAMMMMMMMM door pod installed!! It looks so sexy in there!
  • Schnitzer318is
    • Jan 2008
    • 2057
    Looks good, better than the ones I made.
    I had to ditch them though as they were encroaching on my leg room. I'm 6'8" and I need all the room I can get. Too bad, I really like yours.
    "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
    91 318is Turbo Sold
    87 325 Daily driver Sold
    06 4.8is X5
    06 Mtec X3
    05 4.4i X5 Sold
    92 325ic Sold & Re-purchased
    90 325i Sold
    97 328is Sold
    01 323ci Sold
    92 325i Sold
    83 528e Totaled
    98 328i Sold
    93 325i Sold
    • E30Nova
      • 1546
      So how do they actually attach to the door? Does it just use the stock "clips" or does it also bolt to the door somehow? I'd be afraid of rattling if it just used the clips.
      Matt
      Matt
      I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
      Originally posted by kronus
      try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
      This is like a reverse build thread; it starts out nice and gets shitty.
      • reelop19
        • Jan 2010
        • 770
        Map pockets have the plastic clips at the bottom and 2 screws that you screw into it from behind the door panel. I've been riding around and jamming with my pods for months and haven't had an issue with rattling. Everyone should have these. They add to your cool factor and the ladies love them:)
        • Grif
          • Sep 2009
          • 209
          Those are quite nice I must admit.
          Are you still making them for 150? (The mounting of the crossover on the inside is something I hadn't thought of)
          My car eats bentley manuals.
          • reelop19
            • Jan 2010
            • 770
            Yep I still make them. I just haven't gotten enough interest so I don't keep map pockets or speaker rings on hand. So upon placing a order I will have to get the appropriate sized rings and map pockets.
            • Grif
              • Sep 2009
              • 209
              How long does it take to deliver?
              • reelop19
                • Jan 2010
                • 770
                couple weeks between ordering supplies, building them, and shipping them to you
                • StereoInstaller1
                  GAS
                  • 22679
                  Get your damn crossovers OUT of that door NOW.
                  Doors have water running through them...well, you do live in Florida, but still...get them out of your doors.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • 36brua
                    • 689
                    Hi I'm just starting to look at upgrading system in '89 I so question
                    ? Even though the cross over unit unit is 'protected' by the door card ? water coming through hole for wires ? or open window etc ? TIA
                    My CA legal M60 swap
                    The happening in our garage
                    • StereoInstaller1
                      GAS
                      • 22679
                      just the moisture from the water will make for rusty crossovers...put them where the stock speakers were, the wire run is incredibly easy, plus you already have the tweeter wires there.
                      Besides, electronic components shouldn't be slammed around, right?
                      Closing SOON!
                      • NC325iC
                        • Mar 2004
                        • 6565
                        ^ thats where im putting mine
                        i need to go get some vinyl to cover mine, maybe ill just use a textured paint.
                        • StereoInstaller1
                          GAS
                          • 22679
                          SEM makes a great texture paint. Sand/prime/texture/paint or if you wanna "calm down" the texture, prime again over the texture with a high build.
                          Closing SOON!
                          • reelop19
                            • Jan 2010
                            • 770
                            This stuff is thick and you have to be careful to not go too deep when sanding. If I'm going to do a good amount of sanding on it then I just go ahead and brush over it with a coat of fiberglass resin, sand with 150, and then paint or go over it again with a higher grit depending on the finish I'm going with.
                            • mmire30
                              • Dec 2009
                              • 50
                              Can you paint these natur?
