Central locking problem.
  • LowR3V'in
    • 4209
    Hello.
    locking my passenger side door from inside, I can use the
    trunk to lock all the doors. It works like it should.
    But with the passenger side door unlocked, it will immediately unlock itself.
    Has anyone had a similar problem or know a fix?
    Thinks for looking.
  • Mde36
    • 509
    Yea i had a similar issue, when i unlocked the doors they would automatically lock back before i could open the door. They would also lock at random times when i was driving the car. Even if i pulled them up by hand they would lock back. But for some odd reason it fixed itself. Im still scared one day i may leave the key inside and be locked out.
    Powered By Ford
    • bmw325csi
      • May 2007
      • 4045
      central locking module under knees is taking a dump.
      harry/harout
      • LowR3V'in
        • 4209
        I've replaced that recently w/ no change.
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          its the sensor on the lock cylinder, out of adjustment, take door apart and adjust accordingly
          -Andy
          • payney8
            • Jun 2007
            • 899
            to thread jack this. My drivers side door will only lock. My passenger side door locks and unlocks sometimes and my boot will only lock now. Any ideas? im thinking its the central locking computer
            • LowR3V'in
              • 4209
              Yeah, lock the passenger side door from the inside and see if they all lock
              by using the trunk.
              or just try different stuff like that.
              Mine only locks from the trunk if I have the passenger door already
              locked. Or if I lock the passenger door w/ the key they all lock.
              • payney8
                • Jun 2007
                • 899
                i just disconnected the battery and left it for a while and their all working again:???:
                • LowR3V'in
                  • 4209
                  ..... I will try that.
                  • payney8
                    • Jun 2007
                    • 899
                    see how it goes
                    • Stevo-iX
                      • Jul 2010
                      • 231
                      Any luck? I'm having the same problem. Only with my driver's door. I'm thinking it's a mechanical problem with that door as it's also pretty resistant to being locked unlike the passenger side.
                      • LowR3V'in
                        • 4209
                        I think we have the same problem.
                        No, didn't work.
                        • blocke
                          • 1305
                          I had an issue similar to this. If you take the door panel off, look towards the lower right corner about 3/4 the way down. There is a screw than you can loosen, and slide up or down to adjust the throw for the plunger arm inside. I'm at work, so cant take pics right now. I found that mine had come loose. After adjusting, the door would lock and stay locked.
                          You can give that a shot, seeing as how you've checked all else.
                          Parts Wanted
                          The Never-ending Resto Mod
                          • payney8
                            • Jun 2007
                            • 899
                            Yeah my drivers side door still wont unlock but i think its to do with the barrel as the key wont physcially move that way. So im just going keyless entry and shaving the locks while i respray it
