Basically I'm hearing this sound with out the volume even turned up to even 1, just when the deck turns on the hissing begins coming through the two front and two back 6 inch speakers. And when I press on the accelerator,the hiss grows and becomes a higher pitch. How should I go about re-grounding the wire to the car. And first of all, where do you guys think this connection error is occurring.
Ground Wire Hiss
i got kinda the same thing. I know the battery is grounded to the body well as we had to redo everything when we swapped engines. I'm not sure what the deck is grounded to, probably the stock wiring setup. SHould I just rewire the deck ground to the a chassis point? Is the hiss we are getting coming from the engine ground?
TIA!
DAMN ELECTRICAL GREMLINS!!! -
Make sure power leads and speaker/RCA wires are well separated. If they are run across each other or next to each other you will get cross talk from the power lead.
I run speaker leads on one side of the car, and power on the other.Comment
We call this The Dentist.Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
Absolutely NOT true: never has been. Shitty cheapass unshielded cables are the issue and should not be used in a car. I run power wires WITH RCAs all the time: I do not have noise issues.
Your "hiss" is likely just a shitty noisy korean pile of shit amp.Comment
Ahhh crap!
I knew you'd set me straight.
That's sometin' I was told maaaany years ago and always stuck to it.
Of course back then I was rockin' my Poineer 10 band 100 watt EQ and some ts-695's...shit was HOT I tell ya!
Thanks for straightening me out Luke.
What deck/amp combo, and is it like a "white noise" kind of noise, or more like a whirring that changes pitch with throttle?Comment
I had noise too, followed the pitch and rpm of the motor. Just swapped out the Kenwood deck the PO had in there for one of my Alpines, no noise. I didnt change anything else.sigpicComment
Its a brand new Alpine CDE102 and no additional amp. Just deck and Alpine SPS600C up front and 609s in the rear deck.
TIA, and if you figure out what to do with a strut bar I'd be happy to take one of those boxes off your hands.
Yes its that bullshit throttle noise where the pitch changes. I know the alternator has a funky ground to the motor, I just havent taken the time to change it yet.
DAMN SHITTY NEW WIRES!!!Comment
