Wire joins: solder vs. butt connector
  • nmlss2006
    • 910
    Luke especially has been very negative on solder joins because of corrosion from the flux residual in the soldering. I was, however, under the impression that modern solder spools with RMA rosin cores did not have oxidation issues - whereas the 'normal' RA core does. Could someone shed light?
  • Jean
    • 18228
    I hate butt connectors with passion, so I always kester solder and use heat shrink over the soldered connection for a good electrical/mechanical connection that also looks clean.
    • george graves
      • 19996
      EDIT - Luke thinks 911 was an inside Job, and that the moon landing was a hoax. I'll just let that preface that to this conservation.....Also his "corroded solder joint" argument is totally invalid. This is his red-neck customers that soldered wires with "plumbers copper pipe" solder and/or flux. Not electrical solder. Yes, that will mess up stranded wiring in a hurry. So sorry Luke, wrong again. And if you really want to know all his "PNC" crossovers that he sells, they are all soldered. Every joint is a solder connection. So yea.
      I saw Luke's post a while back - I know what you're referring to.
      Luke is wrong. (sorry Luke!!!)
      If I was installing stereos for a living - I'd use them, they would save time, and let me move more cars. But they are far from "best practice" - if it's you own car, take the time to do it right.
      But, he got me thinking about it - so I started asking a few people. I asked two MIT engineers (one that works building medical devices - crazy stuff) And I asked a third engineer that is an actual god damn NASA solder instructor.
      All of them said that it's fine and normal practice to solder wire. The only time there is an issue is then you don't have the wire supported and it does a ton of bending right next to the solder joint. Basically - anything on your e30 will be fine. Any quality solder made for electronics is fine - solder till your heart is content. NASA requires RMA solder, and that's what all the wiring that is soldered on the space shuttle uses.
      I'm not really a fan of butt connectors either. You're suppose to do a 5 pound pull test after you splice them - and you should be fine.
      Originally posted by Matt-B
      • nmlss2006
        • 910
        Thanks George and Jean! I'm glad to know I'm not the only one who's.. not a fan of butt splices. And I hear what you're saying about possible fraying of the wire at the end of the soldered piece, but I agree, in an E30 that should not be a problem, except *possibly* for solder joins that were in exactly the wrong place on the engine harness (some wires do move as the engine moves). I like the 3M connectors, though I have to wonder how well they work and if they weaken the wire by cutting it? I'll trust your judgement though :).
        • s_ribs
          • 349
          I've come to prefer soldering... but only do it if you learn to do it properly!! Seriously, soldering takes time to learn - a bad connection is a bad connection. Done right they are good connections and aren't bulky so things stay clean looking.
          When I need something quick (or I don't trust my soldering skills) I have shifted to using uninsulated butt connectors. I like to put heat shrink tubing on my joints, and uninsulated connectors are much thinner/bulky than insulated ones. Also, from what I understand butt connectors are better in high movement or vibration areas.
          Vampire clips... I hate 'em! Great for testing before cutting up wires though. ;)
          1991 318i Sedan Project
          • StereoInstaller1
            GAS
            • 22679
            If any of you could show me a solder joint that has been in a car for more than 5 years that isn't corroded I might change my opinion...but butt connectors still win, especially in the professional world, where seat/dash/carpet burns and soldering while upside down etc make it damn near impossible to get any work done and maintain quality.
            You guys have to remember that the average solder job is crap, as is the average crimp. A proper crimp (and EVERY SINGLE crimp of mine passes the 5lb test, unless it is 20ga or higher wire) is best IMO, but as far as typical hackery, I will take a hacked crimp over a crappy solder joint any day.
            If you are one of the rare few who can solder correctly, have at it. Having taken apart hundreds and hundreds of solder joints and seeing how none of the manufacturers use solder on any wire tells me my proof is still correct. I am all about learning something new though, so shoot me a link to this new "non corrosive" solder/flux.
            And George...fucking scotch locks? What bullshit is that? Maybe if you are dealing with .5A or less, but if you are running ANY kind of power through that you are an absolute fucking retard. Microscopic contact area, piss poor oxidization resistance, etc...scotchlocks are crap. I have seen so many of those actually melted from "out of spec" use...well, I just do not do bullshit like that, ever.
            Luke
            Closing SOON!
            Thanks for 10 years of fun!
            • matt
              • 3731
              I am with Luke.
              I will crimp every time over soldering.
              • jeffw
                • 1087
                I'm not really a fan of butt connectors either. You're suppose to do a 5 pound pull test after you splice them - and you should be fine. I'll tell you something I've become a HUGE fan of - these "quick splices". I buy them from 3M by the 100's - and like everything else 3M makes - they are kinda awesome. Really easy to tap(t-into) or extend a wire. You can remove them with a screwdriver it's almost like they were never installed. Once removed there will be a small nick on two sides of the wire's insulation that usually closes up on it's own. Or a bit of electrical tap on the wire if you're really worried about it. But much better/faster/quicker than a butt connector.
                Give them a go - almost any hardware store sells them. I've started including them in the gauges I sell cause they just make such a good connection, carry tons of current if need be, and don't f-up your wiring. Not as good as soldering - but great when you need a quick splice and don't want to hack into anything.
                I only use butt connectors but thats cause i been working with andy lol. and I must say graves these t taps, in my opinion, are crap. they work well for a wire or two but i would never use them to do a full install.
                • s_ribs
                  • 349
                  Luke-
                  The one thing making me completely cool (and perhaps leaning towards some days) is that manufacturers use some sort of crimp connection for everything except computer boards! The only solder I see is in conjunction with a crimp (ex: battery clamps).
                  I am curious how proper heat shrink tubing affects life-time of soldering? On important connection points in the engine bay I use adhesive lined tubing regardless of solder or crimp connection.
                  • Brian D
                    • Mar 2006
                    • 832
                    FWIW, airliners use crimped connections 99.9% of the time. The FAA has found that soldered joints are prone to failure due to vibration. I use the uninsulated butt crimps with heat shrink as mentioned above in any car I work on.
                    George, I know Luke was kinda subtle but I would never use the scotch locks in any of my cars. I've pulled the wiring out of quite a few old cars and those things always (always!) have a lot of corrosion in them and in some cases I have seen them melted a bit, indicating a lot of resistance in the connection. No bueno, my friend.
                    1973 Bavaria
                    • nmlss2006
                      • 910
                      Luke, as far as I know the different types of flux are older than even you :). There's information everywhere, starting from here: http://en.wikipedia.org/wiki/Soldering .
                      I will grant you that if you're in odd positions a butt splice may be easier to make, but you have all sorts of issues, including TWO different metal interfaces, the quality of the connector (a lot of those I've seen seem to be aluminium - an Al/Cu contact join will not last long), the quality of the crimping tool (I can easily bend the ones you can buy virtually anywhere: after that, I can pull the crimp apart almost effortlessly - No, I am not particularly strong either). I am sure one can make excellent crimp joins, but I'll take a quick solder with decent core over the joins that *I* am able to make with equipment at hand.
                      • erik325i
                        • Jan 2005
                        • 3567
                        I solder and heat shrink most of the time. I trust the connection better, and it is much cleaner.
                        Erik
                        • george graves
                          • 19996
                          Luke
                          - It's pointless to argue this. If you don't believe a NASA soldering instructor and two MIT electrical engineers, then fine. No skin off my nose. :)
                          - Solder, butt connectors, quick splices are all tools. You want to use the right tool for the right job. Up inside a dash, I'm maybe soldering iron isn't the right tool to be using. Connecting an amp to power, of course a quick splice isn't the right tool. One isn't universally "better" then the other. :p
                          - Soldering is easy - don't make people afraid of it. Yea, you'll make some joints that look like a turd with thorns poking out of it, but you'll get better with time. :) and at least you can *see* the joint.
                          - half an amp is a ton of current to me. Sorry - I don't think on terms of car amps and shit. So 3m quick splices work very well for my stuff. As far as "Microscopic contact area, piss poor oxidization resistance" butt connectors have the same problem. Any mechanical connection will have that problem. That's why solder is always going to be a better choice if you are worried about that.
                          • StereoInstaller1
                            GAS
                            • 22679
                            I get more experience in 1 year working on electricals in cars than all 3 of those guys get in a lifetime...I say my opinion carries more weight.
                            Butt connectors do not have those issues, as the crimp (and you cannot pull mine apart, I promise) actually forges the wire into a solid structure with the metal of the connector.
                            Tool? Stamped metal piece of shit? NOT allowed in my shop, at all, ever.
                            Recommended: ChannelLock crimpers. Best connection, excellent value.
                            Closing SOON!
                            • StereoInstaller1
                              GAS
                              • 22679
                              BTW guys, don't get me wrong: soldering is necessary pretty often, but in no way is it better than crimping. Crimps are superior in automotive use in ALL ways. If you can't make a tidy bundle of connections that is your issue. My shit is always pretty!
                              Closing SOON!
