Fuel Gauge Stuck on full
  • BrooklynMW
    • 1263
    I realize that instrument cluster issues are pretty common. Fortunately, my odometer hasen't stopped miving yet. But lately, I've noticed my fuel gauge gets stuck on full. Every now and then I can tap my finger on it, or even push on the plastic, and it'll move into it's proper place, but lately it's been getting more and more stuck.
    In the meantime, I am relying on my "range" button on the OBC to tell me when I need gas.
    Tomorrow I will be removing the instrument cluster to change the backlights. Are there any simple solutions to this simple problem that I can do when the cluster is removed?
    '87 325i "Chewey" (RIP, my beloved)
    current:
    '01 e46 325iT "Dot" - #datwagonlife
    '87 e30 325i "Tui" - she has her mother's eyes
  • blacksport325
    • 231
    Did you ever figure this out, mine is acting the same way
    • BrooklynMW
      • 1263
      Nope, not yet.
      But as a temporary solution, push on the plastic with your thumb. (don't tap it, but push it). The needle should drop into place, if only for a few seconds. At least you'll be able to tell if you'll need gas or not.
      current:
      • KMOSES
        • 591
        Mine was stuck on full also. I checked the sending unit with a digital meter and it was good. Replaced the fuel gauge today and everything is working fine. If you are replacing with a used gauge, make sure you get the correct one. The early gauge (up to 9/87) is for the 55L tank, after that you need the gauge for the 60L tank.
        • blacksport325
          • 231
          I tried to push mine but it moves back to the same place it was before, I know for sure the gas tank isn't full...i'm checking the ground later today then I will be looking at maybe disassembling the gauge
          • Gruelius
            • Oct 2009
            • 298
            id love to be able to bury my head in the sand. best of luck.
            RIP 84 323i coupe 5spd w/ 14psi
            89' 318i
            • george graves
              • 19996
              Tighten the brass nuts on the back of the cluster. It fixes 90% of the problems.
              Originally posted by Matt-B
