Not that I necessarily want to have this operating, but my door open chime, when the key is in the ignition, has never worked since I picked up the car from the dealer in 1989. I think it happened when the dealer sent it to an alarm installer (for a so-called dealer installed alarm). I didn't miss the usually annoying "door ajar" chime, but I'd like to know why it's not working. The chime does work for the pre-freezing temp warning and speed setting alert.
More importantly, my driver side window will intermittently stop going up and down. I have to open the door more than half way and then it works. Pull the door back in and it sometimes stops. Other times, it will work just fine. Creates a bit of problem at the local drive-through. I didn't want to start ripping the door apart if the problem is likely not within the door itself.
Any ideas or fix possibilities would be greatly appreciated.
