8 ohm speakers?
  • CO318is
    • Oct 2005
    • 218
    8 ohm speakers?
    I am starting to look at building a diy set of components and was wondering if you can use 8 ohm speakers in car audio builds? It looks like most car audio speakers run at 4 ohms, and most amps are rated at 8 ohms. I am kind of a noob when it comes to this but after looking at the diymobileaudio forum, and bmwman91's build I think diy is the way to go for quality sound.
  • KenC
    King of Kegstands
    • 14396
    Most car audio amps are rated at 4 ohms
    Originally posted by Gruelius
    • george graves
      • 20003
      Yep - what he said
      (most) amps are made to work with 4 ohm. And in some cases lover. Stick with 4 ohm for everything unless you know what you are doing, or (depending on the amp) you'll have trouble driving them - they won't be loud enough is the issue.
      Originally posted by Matt-B
      • StereoInstaller1
        GAS
        • 22679
        Do you understand impedance and how it affects the amplifier?
        When you lower the impedance (from say 8 ohm to 4 ohm), everything doubles: heat, distortion, and power. So, lower impedance (numerically lower) is a heavier "load", so the amplifier (deck power is an amplifier too) makes more power...unless you load it too much, then it lets out smoke.
        It is all a balancing act: load vs. Sound quality vs. money vs. SPL.
        I know I want no less than about 50 watts RMS to achieve the SPL I require, so that means if I want an 8 ohm speaker (there are LOTS of choices) I want to find an amp that makes at least 100 watts RMS rated, so it can have a chance of hitting the SPL goal I have.
        Unless I can find a more sensitive driver, or build more efficient enclosures.
        It is all about the trade-offs.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • Jean
          • 18228
          Or just double up on the drivers lol :)
          • CO318is
            • Oct 2005
            • 218
            Sounds like I would be better off just using a 4 ohm speaker like these
            Free support for loudspeaker projects, sourcing OEM speaker building supplies, and passive crossover design. We sell raw speaker drivers (tweeters, woofers, subwoofer, midrange drivers, full range drivers), speaker kits, amplifiers, capacitors, resistors, and inductors.
            I don't think there are many 100 watt per channel amps out there...
            • Jean
              • 18228
              Seas makes car specific drivers, look into those as well :)
              Half of the work after you select the drivers will be crossover design, testing, re-design, testing and so on.
              I love SS drivers, I currently use them for my diy speakers but I would never put them in a car environment myself.
              • StereoInstaller1
                GAS
                • 22679
                Those pretty much require a small ported box or they will flap and fart like a dog trying to shit out a newspaper.
                Closing SOON!
