Check panel oil level light stuck on.
  • AutoXinE30
    • Aug 2007
    • 277
    Check panel oil level light is stuck on but, according to the dipsptick the loil level is perfect . After some searching is seems fairly common for the sensor in the pan to go bad but not wanting to spend any money right now as we just moved can I just unplug the sensor and and have the light go out or will it stay on? Is there a wire I can cut or a connection I can make to turn it off? Not a fan of hitting the check button every time I need to start the vehicle... :-(
    Thanks
  • JTapper
    • Sep 2009
    • 847
    Replace the sensor. Stupid not to.
    Leave the light on, it will remind you to check the oil.
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
    • AutoXinE30
      • Aug 2007
      • 277
      I already check the oil regularly.
      I just said I don't want to spend the money on a new sensor just yet, its 140 some I don't feel like spending after moving states.
      • JTapper
        • Sep 2009
        • 847
        I have a working one I would sell cheap. A few actually. Post a pic of the plug end on yours.
        • iignite
          • 125
          nahh, just take it out and clean the shit outa it. Theres only a ball/float on a sensor, and sometimes it sticks. I just used some brake/carb cleaner cleaned it up nice. worked ever since, and never had any problems
          • Heysüß
            • 911
            So did this work?
            09/1989 325i 4 Door
            +M30 Swap
            +Z3 Steering Rack
            • Unearth078
              • May 2008
              • 2623
              brake clean in my oil... mmmmmmmm
              Originally posted by Lof8
              4 doors allow you to transport more whores.
              therefore, their value is much greater.
              Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
