Overheating Check Panel light
  • Aus E30
    • Jul 2009
    • 478
    Just wondering if the overheating part on the left hand side is supposed to light up when you hit the *check* button?
    Mine never has and its probably the most major one that should really be working =\
    Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.
    I <3 dead naked girls.
  • jasonsnoddy
    • 1900
    you mean the bulb in the "coolant" box? mine does.
    Originally posted by stewie30luvr
    ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
    Originally posted by JakeP
    with a coathanger
    • netcsk
      • Apr 2004
      • 1609
      And it is not overheating, that is what your temperature gauge is for. It is for low coolant level in the reservoir.
      • jasonsnoddy
        • 1900
        ^^^^^^^^^^^^ +1 just throw some coolant in there
        with a coathanger
        • bmwstephen
          • 2463
          are you refering to the light under the Seatbelt and SRS?
          • Aus E30
            • Jul 2009
            • 478
            Yes that the one! Although I don't have seatbelt or SRS on there, only Overheat at the bottom, which doesn't light up when you hit the test button, just wondering if those panels should indeed light up with the test like the rest do.
            • bmwstephen
              • 2463
              hmm i do you have a picture? perhaps the USA and AUS versions are differ
              • DaveSmed
                • Apr 2007
                • 1406
                Thats your catalyst temp warning light. Non-US market.
                It does nto light up with the test button.
                -Dave
                2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                Need some help figuring out the ETM?
