Antenna Adapter
  • freeride53
    • 11972
    Antenna Adapter
    I bought an universal rubber antenna, but the male - female connectors won't match up with the antenna cable running to the radio. Anyone know where to get the adapter? I've tried kragen, autozone, local car audio, etc, .... a link would be friendly.
    Thanks.
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • freeride53
    • 11972
    anyone?!!?
    • freeride53
      • 11972
      c'mon yall
      • Danny
        • 14216
        Make it yourself with electrical components.
        • der affe
          Technical
          • Dec 2005
          • 8452
          http://www.radioshack.com/home/index...oogle:TM:Exact
          there is your link
          • ethrtyiS
            • 8147
            check frys or check crutchfield.com
            「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
            「my feedback thread」
            • freeride53
              • 11972
              so...is it called a motorola plug? I was hesitant to cut it up since I've heard that makes you loose reception.
              • 318Joe
                • Aug 2009
                • 160
                I'm just as curious. The screw on connector is used by at least one of the after market antenna folks because I got one in the fleabay chinese antenna crapshoot, but I have never seen an adapter, (other than the 20ft line that comes with the antenna) nor have I ever seen a reference to it.
                • freeride53
                  • 11972
                  Yeah, I was prying through some 80's-90's mercedes' at the yard, and they all seem to share the same plug/connector.
                  However, my peugeot, which came with a hirschmann, did not have the odd size plug.
                  • freeride53
                    • 11972
                    If a mod needs to close this, please do so.
                    Found the correct cable/adapter, apparently the plug is the 'motorola' type, after that it was cake.
