Lms-r
  • jrobie79
    • Mar 2006
    • 2525
    Lms-r
    hopefully getting this driver before the end of the week depending on shipping time. Heard many great things about it, but was mainly looking for suggestions on how big to the make the box and what kinda of tuning to tune it to with port area/length etc.
    Mainly looking for Lukes input because he has said that the e30's acoustics may vary from the manufacturers recommended sizes.
    I have seen on other forums people using this sub in about 2 ft cubed tuned down to 33Hz, and just wanted specifics on how big to design based on a coupe e30s acoustics.
    Also if you know of any good amps to power this bad boy, preferably under 200 dollars, probably going to wire it in parallel to 1 ohm to get max power from the amp so 1 ohm stable would be great.
    edit: found this spec sheet if it helps:
    1991 318i ---- 308K - retired
