Proper yellow top for 318is
  • BADCLOWN
    • 399
    i have a 91 318is and will be running the following:
    kappa perfect front components
    reference rear shelf speakers
    600w 4channel alpine amp
    1000w mono alpine amp
    10 inch 4ohm alpine type R
    0 gauge from the bay to the trunk
    anyone running a yellow top and can recommend the proper yellow top for the setup above? their applications program on their website cant provide me with what i need.
    TIA
    FOR SALE: diamantschwarz metallic 1991 m52 e30
    silbergrau metallic 2004 330i ZHP
  • Schnitzer318is
    • Jan 2008
    • 2057
    I'm running one in my 318is... it's much smaller than the OEM battery but I'm just using some foam blocks to make up the difference.
    You're over killing it with the 0 gauge to the trunk... a more appropriate upgrade in these cars is to upgrade the 60amp alternator to something more modern and capable. LOL I routinely hit the low 12's in mine with my electric fans running, AC, and "2000w"mono + "1200w" 4ch amps cranking out the tunes.
    "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
    91 318is Turbo Sold
    87 325 Daily driver Sold
    06 4.8is X5
    06 Mtec X3
    05 4.4i X5 Sold
    92 325ic Sold & Re-purchased
    90 325i Sold
    97 328is Sold
    01 323ci Sold
    92 325i Sold
    83 528e Totaled
    98 328i Sold
    93 325i Sold
    • BADCLOWN
      • 399
      i just had an issue in my old 20th GTI and not having enough power to the back, and it was a mixture of not thick enough gauge to the back + battery.
      what alternator would you recommend to slap in there (m44 motor) and should i just stick with the typical 4ga run to the back to a dist. block?
      • Schnitzer318is
        • Jan 2008
        • 2057
        Well, after some research... we are only offered 80 or 90amp alternators for our cars (was wrong about the stock one being 60, it's 80). I did read you can use a 150amp GM one but it requires some modification/customizing of the brackets.
        I've been running the stock 4 gauge now with no problems for almost 3 years with those HUGE amps. The yellow top should be all you need.
        Also, have you changed your motor? Stock motor for that car is the m42 vs. the later e36 m44.
        91 318is Turbo Sold
        06 4.8is X5
        06 Mtec X3
        05 4.4i X5 Sold
        90 325i Sold
        97 328is Sold
        01 323ci Sold
        92 325i Sold
        83 528e Totaled
        98 328i Sold
        93 325i Sold
        • BADCLOWN
          • 399
          long story short, the m42 was junked and it now has an m44
          should be going to pick up the battery this week.
