how do i add relays properly?
  • Gruelius
    • Oct 2009
    • 298
    hi all
    gotta add a relay to run the LC-1 as my car didnt come with o2 from factory so whats the proper way to do it? i.e. what one would consider a quality job.
    Should i pull battery power and the ignition signal from the fuse box? or should i just run seperate power wire and grab the ignition signal from one of the ignition switch wires?
    Thanks
    RIP 84 323i coupe 5spd w/ 14psi
    89' 318i
