alarm gurus --- am i correct so far
  • r3vde30
    • 142
    Ok tried using some of the stickies but my alarm has a whole lot more wires and some searches yeilded just broken links.
    so here is what i have
    a 91 318is and a Crimeguard 550i6 ---
    here is what I have done so far and I also attached pic of wiring diagram. i seem to have lots of wires left over. Have I done everything correct so
    far? Attached clickable thumbnail of wiring diagram
    ·Main Alarm Harness
    ·2 White Wires---Gray/white stripe and Gray/yellow stripe
    ·Red--- to Red constant + under column
    ·Red/white--- harness came looped into red above---so red constant+ under column
    ·Black--- common ground above brake pedal
    ·Yellow--- Switched + under Column(thick green)
    ·Black/white--- nothing yet
    ·Brown/white--- nothing yet
    ·Brown/Black---- nothing yet
    ·Brown--- siren
    ·Grey—nothing
    ·Pink---nothing
    ·Orange—Nothing
    ·Green--- Green/black by speaker
    ·Blue--- Green/purple by speaker
    ·Violet--- nothing yet
    Locks harness
    ·Brown-not used ?
    ·White/black—not used?
    ·Purple--- common ground above brake pedal
    ·Purple/black--- common ground above brake pedal
    ·Blue--- Green/Blue by speaker
    • Green/Black---Yellow/Blue by speaker
  • StereoInstaller1
    GAS
    • 22679
    ·Main Alarm Harness
    ·Brown--- siren
    ·Grey—nothing
    ·Pink---nothing
    ·Orange—Nothing
    ·Green--- Brown/Purple behind left front speaker (test to make sure shows ground wit either door open
    ·Blue--- To trunk light if trunk trigger is wanted
    ·Violet NOT USED
    Locks harness
    ·Brown-not used ?
    Closing SOON!
    Thanks for 10 years of fun!
    • StereoInstaller1
      GAS
      • 22679
      and go to www.the12volt.com if that is not enough
      Closing SOON!
