head lights and blinkers
  • jdbmw325is
    • Dec 2009
    • 43
    im kinda stumped.
    ok let me see if i can explain this. my passenger side front blinker does not have a bulb in it so exclude that for a second. however i do have a bulb in the front driver side blinker. ok that being said now comes the issue.
    at night when my lights are turned on my driver side light is dimmer than the passenger side ever though i have putt bran new bulbs in... the driver side blinker works fine. during the day when my lights are off the blinker looks like it isn't working, but it actually is. the amount of illumination is so small the only way to see it is if your face is a foot or so from the actual blinker.
    seems like there is weak current to the left side of my car. what should i do?
    the back lights and blinkers work fine.
  • stumble_t
    • Aug 2009
    • 759
    take apart and clean all the connectors in the side markers, front turns, fogs and headlights.
    [IMG]http://www.r3vlimited.com/board/
    • KennyT
      • 542
      Check the voltages at each plug. Might have a bad ground or other issue. Otherwise just clean the plugs up.
