stereo help?
  • ethrtyiS
    • 8147
    stereo help?
    well i did a dash swap about a week ago and since then my radio hasnt work. itll turn on and everything and even power my subs but it wont play jack through the speakers. i checked for continuity and everything from the radio to the amp and amp to the speakers. nothing. could it be that my stereo has gone kaput? any help would be nice. it blows not having music to bump when your in traffic nearly everyday.
    「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
    「my feedback thread」
  • ethrtyiS
    • 8147
    anybody have a clue?
    • ethrtyiS
      • 8147
      bumpski
      • StereoInstaller1
        GAS
        • 22679
        I want a button that forces people to actually describe what is already in their car, and how it is wired.
        Like yours, for example. Could be as simple as you were using deck power on your Alpine and accidentally turned the "POWER IC" off...I have no clue what car you have, no clue what deck, no clue what powers your speakers...how am I supposed to guess what is wrong?
        Closing SOON!
        Thanks for 10 years of fun!
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          I thought you were psychic or some shit
          -Andy
          • IRON-E
            • 16548
            Yeah true, a little more info would be helpful to your cause.
            Any pics of the noodles you rewired?
            @IRON-E30 aka Edwin:D
            • ethrtyiS
              • 8147
              eh my bad. i was rushed. anyways. ive got a pioneer deh-p9200r. everything worked great before i decided to swap in a different dash. i unplugged all the wiring and taped the stuff i need together so i wouldnt lose it. the po ran the fronts and rears through an amplifier. so most of the stuff is already hardwired. my subwoofers work fine, but theres absolutely no noise or static coming from speakers. not sure what the problem is. as i stated above, i did do a continuity as well as a voltage test on all wires. so not sure if i lost a wire or what.
              i know, i know.
              i could provide some soon if need be., there are just so many with this deck.
              • StereoInstaller1
                GAS
                • 22679
                You did test for voltage at the amp...so if you have power, ground and remote at the amp and all the speakers are good, obviously you fried an amp. Not likely, huh?
                Assuming you got all the RCAs back in the right spots.
                Assuming you didn't do something else.
                Go test all 3 power wires on the amp, something is wrong.
                How about some pics of this mess we are dealing with?
                Closing SOON!
                • ethrtyiS
                  • 8147
                  well i checked for continuity of the incoming and outgoing wires. so its definitely making it the speakers. fuse on the amp looks fine, amp turns on fine. could it possibly be a fried amp? not sure how that would have happened though. i will go take some pics right now if i can find my camera.
                  • ethrtyiS
                    • 8147
                    alright well heres what i got. i cant seem to find my voltmeter now, so i cant check anything atm.
                    heres the mess:
                    acc:
                    constant power:
                    positive + negatives(note that there are more because ive also got an ipod charger and a pa system hooked up):
                    rca's(front+rear+subs):
                    • StereoInstaller1
                      GAS
                      • 22679
                      Travis, how are you testing fuses?
                      HINT: only a testlight will properly test a fuse...and if you are going by the lights on the amp, they lie too.
                      TEST with a testlight. Make sure you have power, ground and remote.
                      You cannot test a fuse with your eyes these days!
                      Closing SOON!
                      • ethrtyiS
                        • 8147
                        i checked the fuses using the voltmeter and they seemed to work fine i will triple check all wires again then. i wonder if a new hu would solve it.
                        • StereoInstaller1
                          GAS
                          • 22679
                          The reason I suggest STRONGLY that you NOT use a meter to test fuses is that the meter is capable of reading "ghost" voltage that even a defective fuse (thanks, China!) can pass.
                          Seriously, get a testlight. $5.00 at most any auto parts store.
                          Closing SOON!
                          • ethrtyiS
                            • 8147
                            alright well ill go ahead and pick that up tomorrow morning and give it a go. do you think it could be anything other than a fuse? i sure hope thats the case, although, only the fronts were being powered by the amp while the rears were still being powered by the stock amp. po did a shitty hack job.
                            • StereoInstaller1
                              GAS
                              • 22679
                              Ah, more details.
                              Sounds more and more like a remote wire issue.
                              Closing SOON!
