head unit wont power up after cutting OBC harness
  • der affe
    Technical
    • Dec 2005
    • 8452
    I removed my euro clock and cut the harness out because I sold them. I cut the harness with both the ground and the positive cables disconnected. I bell capped the wire ends then reconnected the battery cables and now the deck wont power up of the 4 wires that I capped 3 were neg and 1 was constant power.
    Does the deck power run through the OBC harness ( or maybe the ground?).
    Everything else works and there are no blown fuses.
    Guidance is greatly appriciated!
  • AndrewBird
    The Mad Scientist
    • 11898
    Aftermarket deck or factory? If it is aftermarket, it sounds like who ever installed it tapped into power from the OBC and didn't use the factory wiring.
    • der affe
      Technical
      • Dec 2005
      • 8452
      Aftermarket alpine digital only. It LOOKED like they cut the factory harness and wired it in using the factory wires, maybe not I guess............
