Instrument cluster help
  • NO SHAM3
    • Dec 2010
    • 28
    Finally installed a radio in my car and to my surprise the tach started working. The problem is that I can feel the car redline at about 4000 RPM. How do I find out if the right cluster is installed in my car?
  • crazyman
    • Dec 2010
    • 738
    What year is your car? For the older ones usually it's VDO, the newer ones they started putting in moto meter cus they were better. I swapped out my VDO dash for a moto meter dash cus they work better. That was plug and play for me.
    85 swartz/metallic 325E
    84 alpine 325E
    85 zinnoberot 318i/R.I.P
    84 Bronzit 318i/sold
    purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
    • NO SHAM3
      • Dec 2010
      • 28
      its an '89
      • crazyman
        • Dec 2010
        • 738
        It might be just a ground issue for the tach to be not accurate. I'm not sure how yours is but on my 318i the harness for the dash routs right behind the sterio, so it's possible that a wire is pinched and causing that. If that doesn't turn anything up I would just try swapping it with another tach to see if it still does it, for starters. I'm going to go ask my buddy about it to see what he thinks, then I'll let you know what I find out.
        84 alpine 325E
        • AndrewBird
          The Mad Scientist
          • 11897
          Check the coding plug in the cluster. It's on the bottom right portion on the front of the cluster. If you have the wrong coding plug in, the tach won't read correctly. There is one for 4 cylinder cars and one for 6.
          • crazyman
            • Dec 2010
            • 738
            Ah so that's what that stupid plastic thing is in the back of the dash. I always wondered what the hell that was for. Thanks for the info
            84 alpine 325E
            • NO SHAM3
              • Dec 2010
              • 28
              Thanks guys I'll check it out and let you know. My holiday work schedule is hectic right now.
              • bmwm42
                • 6300
                if your car is a 325e your redline is only like 5k rpm
                Originally posted by bmwm42
                PNW vulture pm me for parts
                Strategic nw e30 command
