Help!!! No Right Side Door Power
  • baxtere30
    • Jul 2010
    • 49
    Ok, so I need some help. I have no power going to the pax door. Neither the window or the lock works on that side. Drivers side functions fine. Any ideas? I put power directly to the window motor and it worked fine. Replaced the switch with a known working switch and still nothing happens with the window. As far as I can tell the right and left sides arent on different fuses/circuits are they? Any help would be appreciated!
    Thanks
    87 Alpine/Cardinal 325is (R.I.P)
    96 E36 M3 - Dinan'd
  • DaveSmed
    • Apr 2007
    • 1406
    What year is the car?
    If its a late-early model or a late model, there is a large round connector in the door jamb that likes to fill with water.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • baxtere30
      • Jul 2010
      • 49
      Its an 87... Feb build
      96 E36 M3 - Dinan'd
      • DaveSmed
        • Apr 2007
        • 1406
        You have it then.
        The terminals like to rot off inside that plug.
        -Dave
        • baxtere30
          • Jul 2010
          • 49
          Thanks... I'll take a look at that and see what I can find out...
          96 E36 M3 - Dinan'd
