Yo Luke - what's your take on those big capacitors?
  • george graves
    • 19996
    #31
    Yea....in theory is should really help everything in the car out - like literally everything that electrical should be able to benefit from it. Why doesn't it? I don't know - maybe the battery's internal resistance is much higher than you expect - just a guess.
    Automotive electrical systems aren't like anything else - they are wired in these odd ways, and generally use way too small of gauge wire (somehow getting away with it) Oh, and god the noise, alternator load dumps, 100 volt spikes, -20V negative spikes, low cranking voltages. It's a fucking mess.
    So - in your experience Luke, it doesn't let smaller amps hit a bit harder? Or keep lights from dimming on? I could see how on a competition system if would have less benefit, I just thought on an average e30 with a deck and a few amps(small stuff), it might give a noticeable boost to the things.
    Originally posted by Matt-B
    • u3b3rg33k
      • Jan 2010
      • 2452
      #32
      Originally posted by Vtec?lol
      ...so if you have a 1800W amp and your pushing 4ohm loads of sub-50Hz bass, your 2farad cap is now leeching and killing your charging system.
      This is the biggest bunch of malarkey this forum has spewn out in, well, days. What you meant to say was your stupid trunk rattling ricer special is killing your charging system.
      Automotive electrical systems aren't like anything else - they are wired in these odd ways, and generally use way too small of gauge wire (somehow getting away with it) and god the noise, alternator load dumps. It's a fucking mess.
      In my unsolicited opinion, it does "help". If nothing else, it smooths out alternator ripple current, which, unlike that of a half decent DC power supply, is in the tens of amps (or more), not milliamps. Most things in a car are supposedly built to deal with this: ECU's must tolerate a wide variety of voltages (down to whatever the minimum voltage will be while cranking in the dead of winter with a weak battery), ignition noise, crappy common ground systems *cough* *cough*, etc...
      Can the average person notice a capacitor smoothing out ripple? I doubt it. Is removing AC from a DC system a good thing to do? Generally, yes.
      As for automotive electrical not being like anything else, I disagree. MOST wiring systems are designed on a budget (thank goodness for the NEC).
      The only major difference is the common ground system, which is a stupid way to save weight. I'd rather the car had 75# more copper in it than the weight savings of common ground (it's even worse when sensors are common ground).
      What kind of moron would wire a bathroom, a hallway, and an outdoor outlet on the same 15A circuit? The kind that would drop two wire gauges in a car to help out the bottom line.
      Ich gehöre nicht zur Baader-Meinhof Gruppe
      Originally posted by Top Gear
      Just imagine waking up and remembering you're Mexican.
      Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
      • george graves
        • 19996
        #33
        If a capacitor smooths ripple in the forest, but no one is there to see it, does it really matter?
        If everything in the car is built to deal with it, and there isn't any positive effects - so unless you drive around looking at a scope...what's are you going on about? I'm lost. I've missed something.
        • u3b3rg33k
          • Jan 2010
          • 2452
          #34
          Snake oil?
          They do what they claim?
          What's the deal?
          Capacitors do what they're designed to do, store charge. If you want snake oil, look no further than this:
          Originally posted by Schnitzer318is
          After [capacitors] are drained they are just another draw on your alternator.
          Were you expecting a free lunch?
          As for those of you calling me a stupid college kid, really? Half of the EE students I've met can barely figure out how to test a 9V battery. Most of what I know I learned by doing, reading about it is just good practice. Sometimes it blows up in your face, but most of the time it works just fine.
          Well I think there are positive effects. Capacitors have lower internal resistance than batteries, so they'll do more discharging and recharging than the battery, evening out load on the alternator should make life easier for it. Systems at a steady state generally seem to hold up better than those constantly in flux.
          Compare it to a well pump that is cycling on and off constantly, and one that is running continuously - the one that is just on will almost always outlast the one cycling on and off.
          • Jparkr
            HR Admin
            • Jan 2006
            • 3494
            #35
            Wow, you are, like, so..... smart. I'm going to change your name to StereoInstaller2 if you keep it up.
            Ps. Don't keep it up. Your opinion was not originally asked for and despite that has already been stated here several times. If you wanna argue such minuscule details, you can go somewhere else.
            1987 PRO-3 car /1990 325is (2.7i Concours)
            • Vtec?lol
              • Dec 2009
              • 3278
              #36
              I guess you could put it that way...
              • Schnitzer318is
                • Jan 2008
                • 2057
                #37
                LOL... I still think they are a waste of $$$, as Luke does apparently. I'll continue to not use them in my "ignorance."
                PS: I also like the pretty digital voltmeter lights that they display, unfortunately they are almost always in the trunk where no one can see them.
                "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                91 318is Turbo Sold
                87 325 Daily driver Sold
                06 4.8is X5
                06 Mtec X3
                05 4.4i X5 Sold
                92 325ic Sold & Re-purchased
                90 325i Sold
                97 328is Sold
                01 323ci Sold
                92 325i Sold
                83 528e Totaled
                98 328i Sold
                93 325i Sold
                • europeanplates
                  • Jun 2005
                  • 1607
                  #38
                  I will have to get out my old stereo pictures. I did a couple DB drag cars that had 10 and 14 1 farad units. Do the work? They did in my systems; but these where mega dollars systems.
                  Tyler
                  http://www.europeanplates.com Build and Preview plates
                  R3V Discount Code = R3V2012
                  • bloodshot-e30
                    • 1494
                    #39
                    i had a 2 farad cap with 1400 watts+ of power and 2 speaker amps and it never dipped below 12.5 volts at idle with my M52 swap
                    ^Back in the game^
                    BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
                    FS thread:
                    http://www.r3vlimited.com/board/showthread.php?t=214105
                    • Jean
                      • 18228
                      #40
                      Also consider that car amplifiers aren't exactly using your 12 volts to make music, instead the 12 volts are used internally by a switched power supply circuit to make 2 rails (positive and negative) of 20-50 (on average) and have it's own line of capacitors PER rail to keep the voltage smooth DC like.
                      So, if you have a shitty amp putting a big cap before it might make a bigger difference vs. putting one on a high end or quality amplifier.
                      • Jean
                        • 18228
                        #41
                        Hmmm. I'll have to check what I have. I have a m30b35.
                        You don't need a cap dude, b35s have manly alternators.
                        • immajackuup
                          • Dec 2010
                          • 1132
                          #42
                          So whats your take on flickering lights with bas hits?
                          bad alternator.
