What was behind the after market HU
  • DaveSmed
    • Apr 2007
    • 1406
    Originally posted by jjc-hi
    OK back to the original problem. The dome light relay is warm so I need to replace this right? $120 new. Will this have any impact on the power locks?
    You should buy george's module. Modernize the car a bit and save some $ all at once.
    It also sounds like you might have unloader relay issues.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • jjc-hi
      • 125
      I am familiar with his temp sensor. What module are you referring to?
      • jjc-hi
        • 125
        ETM shows a 25 amp power window circuit breaker. Where is this located?
        • Todd Black 88
          • Oct 2007
          • 3449
          Thats the window cut out switch on your console
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • jjc-hi
            • 125
            Does it have a changeable fuse in it? Before I lost power the lights on the buttons were cutting off intermittently. This happened when I was removing the auto window controllers that were spliced into the window button wires. Or do I maybe need to get a new circuit breaker?
            • jjc-hi
              • 125
              Not sure what happened but power windows are working again. Had changed a few old fuses earlier then put the doors cards and front speakers back in. Turned the car on and the window switches lights were working and the power windows worked. I am happy.
              • jjc-hi
                • 125
                OK, car's back together and running nicely. I stopped by one of the better known indys in town a talked to him about the locking problem. He tried the key in the lock and when he saw it got semi stuck trying to go into the lock position he said the first step is to replace the actuator. After this is done he said he would test the central locking unit. Does this sound right? If so I can order the part and install it myself.
