Awesome 10" Woofer
www.gecoils.com
My euro 316 project Transaction FeedbackComment
For example, lets say we have a class D monoblock amp, rated to make 1000 watts at 1 ohm. If you run it on 2 ohms, it only makes 500. At 4 ohms, it only makes 250. Makes sense to run it at 1 ohm, right? Well, no amount of wiring or bullshit will get you to 1 ohm except using an appropriate woofer.
Now, getting to 1 ohm can be tough. There really are no 1 ohm woofers (any of you that know a stock 2001 Carrera sub is 1.4 ohms, just shut the hell up, you already know this shit) but a dual voice coil 2 ohm per coil will be 1 ohm when wired in paralell...just as 2 dual 4 ohm does 1 ohm...or 4 4 ohm SVC woofers, or 12 12 ohm woofers...whatever it takes to get to 1 ohm, see?
If you are using a 2 channel amp in "bridged" mode, each channel sees twice the load...meaning a SVC 4 ohm woofer on a 2 channel amp shows it 2 ohms per channel...but that does not apply to a true mono (1 channel) amp.
Hope that clears it up...there is ZERO advantage other than the ability to "load" your amp properly.
LukeComment
I've always kind of viewed it as use a DVC sub if you want to run a dedicated sub amp (with another amp for components) and use a SVC sub if you want to run it off half of a 4 channel amp (the other half being used for components). This is a rule of thumb type of thing anyways, and isn't the final say of course.Comment
Oh, and are the specs listed on Amazon for that 4-channel Obcon amp correct? 1000w peak, but only 4x50w RMS? How lame is that!Comment
4x50 at 4 ohms RMS is not bad for $50. Its probably 1000w max bridged at 2ohms (theoretically).Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
BS rating. basically.
Luke - check your PM :)Last edited by Jean; 12-08-2011, 01:49 PM.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Just bought mine. Available here for 33.99+sh
Past: 1987 325iS, Bilsteins - HR Sports
Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor MountComment
I just picked up one of your boxes locally and since it can't fit my Orion HCCA 10" can you suggest this (or another sub) as a SQ sub that runs well with the HCCA 225 amp @2ohms?
BTW if I take a pic of my MBZ 190E-16 trunk can you make a BEAST box for it??Rich!Comment
However, that big bitchin HCCA woof will fit our E30 Beast boxes...
Let me know exactly which 225 you have and what impedance you want to end up at. We will pick a good woofer for you, no worries.
LukeComment
