Headunit problems
    Headunit problems
    Well my headunit worked fine for the past 2 months but 3 weeks ago it started goign off whenever I went over bumps or took turns and it got worse and worse to the poitn it would turn ont hen turn off constantly and I could do nothing to it. So 2 weeks ago I decided to check my connections and everythign looked good and the headunit worked when I slid it back in suprisingly, but then it started happenign again it started otu slowly then got worse. So today I decided to check all my grounds and connections to everything so I checked all my amps and my headunit again adn redid the connections. When I put everythign back together it worked perfect but the first slightly sharp turn I took it turned off then came back on for a second then went off again. Somethign I noticed tho was that my antenna was no longer traveling up and down it was stuck. Since the headunit uses the antenna as a ground could this be why it is coming on quickly and going off?
    Why would you think your antenna is the ground for your headunit?
    Brown is the factory ground, or run another...do NOT use the antenna as a ground.
    Good luck,
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
