Hi guys...Like the title says, I do not have any power going into the ignition switch (red wire, I tested before the connection), hence nothing happens when I turn the key...I ran 12v straight from the battery to the ignition switch and made sure the ignition switch is functioning properly. Is there a fuse im missing somewhere? and I assume it would not be recommended to run a wire straight from the battery to the ignition switch (fused)? TIA
