fuse 23
    fuse 23
    I keep on blowing that fuse when i turn my lights, i know its related to the illumination wire.
    Where im stumped is that the wiring from the dash has 2 grey/red and 2 browns (thick/slim). I wired the deck illum to one of the grey/red and capped the other one. Grabbed the ground from the thick wire and capped off the slim wire.
    What am I doing wrong?
    Btw, this is non premium.
    Did some more testing and the fuse doesn't immediately pop, it goes out after a couple of times of turning the headlights on and off.
      Was the board down?
      The source of my problem was that one of the rear brake lights started to get corroded in one of the metal pieces that distributes the ground, apparently the rust was sometimes shorting the ground because i cleaned them up and its working great now.
        Same thing happened to my car.
          Sounds like you guys got your radio wired up wrong.
            Have a stock radio, and even tried a good headlight switch. Pulled the plastic cap off the top of the trunk and I had pinched wires or something back there, I cant remember but it was the wires leading to the tail lights. But its fixed now.
