325i and 325is wiring difference??
  • tfritz
    • Jan 2008
    • 590
    Found a 199 325i auto shell that im thinking about buying to swap all of my 1990 325is drivetrain and such into. The shell has all wiring intact. My question is, are there any differences between the wiring in the two cars? Will my obc, guage cluster, trans, etc. hook up? Do I need the computer out of my car?
    Any input would be great.
    Thanks.
  • devon.818
    • Feb 2011
    • 2937
    it wont hook up.
    you'd need to cut into firewall for brake/clutch pedal assembly.
    but if you just transfer everything from the parts car to the shell, then i think it would be pretty straight forward.
    i think the only wiring when doing a 5sp swap has to do with the starter.
    all i know.
    • ttrousdell
      • Nov 2009
      • 1770
      90 325i and 90 325is have same engine and same harness. should be same 173 dme as well. you will have to deal with the neutral safety switch if the 325is tranny is manual
      The Build:
      • devon.818
        • Feb 2011
        • 2937
        thats what i was trying to think of!
        i knew it had a funny name
        • tfritz
          • Jan 2008
          • 590
          I guess I did not specify, my car is a manual. Is there a writeup for a auto to manual swap? I just looked here and on e30tech and didn't see one.
          • devon.818
            • Feb 2011
            • 2937
            here
            probably the best and most detailed write up online. yoshi is known for being very detail oriented in his write ups.
            i was gonna use this as a bible but then decided to just buy a 5sp. coupe
            • tfritz
              • Jan 2008
              • 590
              thanks!
