It looks like im not the only one atm with this problem. I had one reply after 30 views on e30tech and need to figure this out. I bought a new head unit which was a pioneer. My old headunit was an pioneer as well, I had to use the new wiring harness cause pioneer made some changes to the plug on the new unit. I hooked everything back up the way the old one was but this wiring harness had an remote " blue wire" and Acc " red wire" . Since the old unit didnt have either I just didnt hook them up. I plugged the battery back up and the headunit did not work. I then hooked up the acc wire to a purple wire that was just plugged off which had power and it all worked. The next day Im blowing fuses ???
This is what I posted on my thread on e30tech:
Took the license plate connectors out everything looked good. Check to see if I was getting power to the out lights with a 12v wire checker and got nothing. Wiring isnt really my area of expertise, what could I check next for a short. Right now my rear brake lights are working, only my left tail light works with lights on and headlights and front runners are working. Instrument cluster and center console lights are out behind hvac controls. Im wondering if I could have caused a short behind the head unit when I replaced it last week. Im stumped
Any direction would be greatly appreciated
