ok, i STILL do not have my ms2extra running in the car.
everything checks out, i found that i was missing a wire in my c101 at the fuse box side and replaced it. it was to the VSS sensor so i don't think it had anything to do with it.
i am still not getting the injectors to open, but according to the turner studios readouts they are getting the signal to fire. the fuel pump does prime and i have pleanty of fuel and fuel pressure.
here is my question........
in the picture there are 3 LEDs
the one on the left NEVER comes on
the center one comes on with the key and stays on solid when cranking
the one on the right comes on momentarily and dimly when the key is turned on, then flickers dimly when the car is cranking.
is the dim LED a clue to an issue?
should the one on the left turn on at some time?
i am about out of ideas and am begining to wonder if it is an ECU problem making the injectors not fire.
