looking for low profile subs
  • devon.818
    • Feb 2011
    • 2937
    i want good thump, so im thinking 1 12" mounted to the back of of my rear seat in trunk would do it.
    any experience with these, any suggestions on what to get?
  • devon.818
    • Feb 2011
    • 2937
    bzzz
    • devon.818
      • Feb 2011
      • 2937
      anybody?
      • KenC
        King of Kegstands
        • 14396
        Mounted to the back of the rear seat? The rear seat sits right against the bulkhead there. There's no room.
        Originally posted by Gruelius
        • devon.818
          • Feb 2011
          • 2937
          there is definatly room.
          i dont want a box though.
          so im thinking either behin rear seat in trunk or under driver/passenger seat(sub under my seat anmp under passenger).
          just asking what subs would be good to use, im not familiar with audio stuff.
          • KenC
            King of Kegstands
            • 14396
            You're right. Just cut a hole in the rear bulkhead and screw a 12 in there. It'll sound fantastic.
            • devon.818
              • Feb 2011
              • 2937
              thanks mr.condiscending.
              • KenC
                King of Kegstands
                • 14396
                I'm being honest. You can't squeeze a subwoofer magnet between the rear seat and the bulkhead. Unless you want to smash it into the seatfoam and block the vent hole.
                • devon.818
                  • Feb 2011
                  • 2937
                  between?
                  i was gonna mount it facing into the car but have it in trunk, same idea as putting a full box in the trunk but having the subs faced in.
                  ^^^people do that all the time and it sounds fine, so where would you put the subs?
                  • KenC
                    King of Kegstands
                    • 14396
                    When you said mounted in the trunk it sounded like you wanted it firing into the trunk.
                    If you put a grille over the driver, you could squeeze it back there. The Luke Box is pretty low profile though.
                    • devon.818
                      • Feb 2011
                      • 2937
                      yeah but im not really looking for a box,.
                      something like this
                      for me i think it would hit hard enough.
                      • airkhin
                        • 593
                        luke box, cant even call it a "box". it doesnt take up any room, and it is more than you will ever need. luke box. period.
                        • StereoInstaller1
                          GAS
                          • 22679
                          Devon, are you trying to have no box at all? That type of install is called "Infinite Baffle" and basically uses your trunk as a box. That type of install can sound wonderful, as long as you don't listen to anything with actual bass content, or plan to play it loud, ever,
                          The issue is that the box is the woofers suspension, that is what controls the cone movement of the speaker more than anything.
                          You really can use a $40 woofer and a $50 amp and get deep, clean great sounding bass in one of my boxes. An infinite baffle setup in inherently inefficient, takes a ton of power and a woofer capable of both flapping around in free air and (because it is flapping around loose) needs to be able to handle a ton of power.
                          So, if you listen to ONLY 50's and 60's pop/rock at quiet volumes, or Jazz, IB can work really really well.
                          Here is a pic of the 12" box installed (the 10" is 2" shallower):
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • IRON-E
                            • 16548
                            OP; you seem to be trying to re-invent the wheel.
                            Do you know that guys like Luke have been in the audio business for years and that this method was tried before and failed?, hence the reason why there is such a thing as a Luke Box.
                            I don't own a Luke product but I have personally seen and heard, how hard the sub kicks in the box configuration in the trunk.
                            Good luck to you Sir. because unless you delete your glovebox or cut holes into the engine firewall, I don't foresee this happening, any time soon.
                            @IRON-E30 aka Edwin:D
                            • blacqjak
                              • 95
                              do you have a link to where i can get a luke box?
