Another option, this is how I got my HU out with no keys. Slip a knife around the perimeter of the cage, between the cage and the console. There are thin tabs stamped into the cage that are bent upwards to hold the cage in place. I used a paring knife and slid it around the perimeter until It would stop. By feel, you can tell which way the tab is bent. If the knife stops going one way, but can go past the same spot going the other way, you can determine the direction to bend that tab back down onto the cage. When the knife moves freely around the perimeter, you should be able to pull the whole radio out still locked within the cage.
