Electrical Issue 89 325i
  • AlpineM30
    • Jul 2010
    • 58
    Is there a fuse or relay that controls the power windows, Blower motor and the back light behind the AC control knobs and the window switches? basically when i'm driving my car All these thing will go on and off randomly at the same time. When I turn on my car it wont work, then ten minutes later it will work for 20 minutes or so then stop working. what could be causing this? Any help would be great.
  • jaywood
    • Jul 2010
    • 4528
    Fuse 17 is for the power windows
    • StereoInstaller1
      GAS
      • 22679
      HVAC and Windows are powered through the unloader relays. For starters, check the wires on your starter. If the green/black is loose, you lose HVAC and Windows. The panel lights are unrelated.
      Closing SOON!
      Thanks for 10 years of fun!
      • AlpineM30
        • Jul 2010
        • 58
        when I looked at my starter I fount the top ground cable to be very lose so I just tightened it and the problem that I was having is fixed now. It sucks not having working windows. Do any of you know how to fix the backlight behind the A/C Controls?
        • StereoInstaller1
          GAS
          • 22679
          EDIT: you are welcome.
          Take your radio out and replace the bulbs?
          Closing SOON!
