It's nothing special. Just an older Sony Xplod XM1502SX. It says 760w bridged but only tests at 380w bridged. Which is fine with me. It's pushing a 12" kicker in a non ported box. I would like know the best settings for the amp. I don't care about a lot of bass just wanted it a little cleaner. I have the level only set half way so I don't run the risk of blowing the sub.
The settings on the amp are:
Cut-off frequency adjustment control 50hz-300hz
Low pass filter - off - high pass filter
Low boost (40hz) 0db - +10db
Level Min-Max
The rest of the car I'm running a Dual HU (nothing fancy, got it and the kicker on sale at Best Buy for $99) that's powering front Kenwood 5.25", premium stock tweeters, and 5x7 JL Audios in the rear shelf. The car had no system at all when I bought it so it's been pieced together over the years. I've had the JL's about 11 years and they still sound great. The Kenwoods center tweeter sticks out a little and the trim piece bulges a little over the speakers so I'm sure that doesn't help. Also I have the bass on the HU at +1 (out of +6) and treble at +5. The sub output from the HU can be adjusted from off to +12. I usually keep it at +8. Any help from the gurus here? I'm ok with the sound now but I'm always looking to maximize the use of what I've got.
Level Min-Max
