Radio problems
  • Purdue89E30
    • 991
    Radio problems
    I installed a Blaupunkt headunit a while ago. Now when my engine is in higher revs I get a lot of interference with my radio. Would replacing my spark plugs with resistor plugs do anything to solve this problem? Does anybody know how well these plugs work in e30's? I know they can be finniky when it comes to the type of plugs you put in them. Thanks
    "One of my top five favorite, like, cool...nerd cars"
    '89 325i-sold
    '98 528i
  • T.Dot E30
    • Mar 2004
    • 536
    huh? what does spark plugs have to do with ur stero?
    Check ur grounds for the whinning noice, or rca's.....it could be just about anything. (except spark plugs :idea: )
    • Purdue89E30
      • 991
      Spark plugs DO affect your stereo! Read this:
      and this (from the Bosch website):
      "Resistor- Many spark plugs have a special conductive glass seal between the center electrode and the terminal stud. This seal acts as a resistor in the plug which reduces the transmission of pulses of energy to the ignition cables. These pulses can cause Radio Frequency Interference (RFI) with electrical components in the car. For some newer cars, resistor plugs are required for effective communication between the plugs and the electronic ignition."
      Now can someone who knows what they're talking about help me?
      '89 325i-sold
      '98 528i
      • T.Dot E30
        • Mar 2004
        • 536
        ok budding go change ur spark plugs....
        If you had a decent amp and set it up properly you shouldn't have this problem.
        • AndrewBird
          The Mad Scientist
          • 11892
          Apparently you have never seen resistor plugs before. And they do affect electronic devices. This may not be the cause in his case, but it is a possibility.
          Try searching. There are many threads on this topic.
          • T.Dot E30
            • Mar 2004
            • 536
            Well im sure it exsist, i dont see the need for em when there are other more practical ways to solve this problem.
            • AndrewBird
              The Mad Scientist
              • 11892
              Like I said, it might not be his problem, but it is a posibility.
              • Purdue89E30
                • 991
                Thanks Nitro
                and... uhh the other guy too, I guess
                '89 325i-sold
                '98 528i
