How high to mount my sub?
  • 808BMW
    • 2910
    How high should I be making my box?
    I was thinking build the sides 8" high. That would give me 6" of space to the top of my trunk, and 16" of mounting depth.
    My sub will be firing straight up, should I try to angle it? Like build 1 side 10 inches and the other side 6 inches?
    Once I figure out the outside dimensions, I can work on a port. I just don't want to have my sub sitting 1 inch away from the roof, or will that not affect it?
    I could easily move it down... My plan for this box is to run a single DD 9515... only need 8 3/4" mounting depth for that...
    How important is it to have space in the trunk not taken up by the box?
  • UNHCLL
    • 8789
    dimensions should be dictated by the required air volume the sub needs given the design of the box. A ported box will require more air, and a sealed box will require less air.
    Below the radar...
    • Jordan
      • 12911
      Idealy you want the sub to me mounted on a horizontal face, or on a obtuse angle.
      otherwise it is fighting gravity, with a result of reduced output.
      https://mtechniqueabs.com/
      • FergU
        • 43
        Only 1/2 the time, the other 1/2 gravity is helping it. In otherwords, gravity is not the issue.
        • Jordan
          • 12911
          Well what is the issue then Ferg?
          • FergU
            • 43
            The only down-sides of mounting subs facing up are; even more rattles as they are often hitting directly at the trunk lid, and the chance of debris falling onto the cone and rattling.
            • 808BMW
              • 2910
              So facing it up is completely fine?
              The main thing I'm wondering is: Do I need space outside of the box?
              I don't think having the sub 1 inch away from the top of my trunk could be all that good, but the farther I go down, the more airspace of my box I lose.
              • BMW BMXER
                • 2325
                As long as at ful excursion the sub doesn't hit anything it should be fine.
                Rattles are another story.
                Sold it.
                • 808BMW
                  • 2910
                  Holy shit If I can find a sub with over 6" of excursion...
