True e36 one touch windows DIY
This is a sticky topic.
  • KingjGar
    • Feb 2014
    • 32
    #91
    Awesome!! Thanks
    M Technic Badge Replicas for sale
    http://www.r3vlimited.com/board/showthread.php?t=336902
    • yanal
      • Jun 2011
      • 248
      #92
      Please make sure you post your questions here, I get a lot of PM's with the same questions, other members will be able to see question/answer in the thread.
      Sticky:True e36 one touch windows DIY
      1990 M3
      1992 Mtech (S50 + 5 Lug)
      • gmont02@yahoo.com
        • 53
        #93
        can this do 2 windows with one switch? i asked george if his kit can and he said no. just looking for a cleaner look on my vert and delete two switches, plus not to mention 150x4 is kind of a rip off imo.
        '87 cabby parting
        sigpic92' calypso cabby preparing for storage
        • george graves
          • 19992
          #94
          I didn't say it couldn't be done, I said I wouldn't do it because I 100% believe you wouldn't like it. :) Maybe that's what you meant.
          If you really want a "clean look" and only 2 switches, maybe consider hiding the rear switches in the ash tray? Hope that helps.
          Originally posted by Matt-B
          • gmont02@yahoo.com
            • 53
            #95
            not a bad idea, but highly doubt i would do it. the thought of opening and closing it lol
            '87 cabby parting
            • gmont02@yahoo.com
              • 53
              #96
              So bump?
              '87 cabby parting
              • yanal
                • Jun 2011
                • 248
                #97
                Originally posted by gmont02@yahoo.com
                So bump?
                You could do two windows with one switch, but you're going to need two modules, and you need to modify both modules.
                1990 M3
                • Mahalaleel
                  • 180
                  #98
                  A bit better way to do things...
                  New custom circuit board - my own design, fully rebuilt switch. New LED, resistor.
                  Ah yes, that looks nice:
                  Are you selling these? I'd like the simplest and most elegant one touch install possible.
                  • george graves
                    • 19992
                    #99
                    Yes, see here: http://www.r3vlimited.com/board/showthread.php?t=296371
                    • Garrick2007
                      • Jun 2014
                      • 59
                      #100
                      Can this be done with e38/e39 switches? I rather the look of these switches and someone hacked them for use in e30's before but not for one touch, they fit nicely with a little bit of filing. If anyone knows how please let me know. If not I kind of think I may be able to rap my head around this guide and add the module onto it. Resource: https://www.bimmerforums.com/forum/s...One-Switch-Mod
                      • george graves
                        • 19992
                        #101
                        Originally posted by Garrick2007
                        Can this be done with e38/e39 switches....but not for one touch
                        Short answer is no.
                        Long answer is yes, but not without modifying the switches, and enough wires that would look like a bowl of spaghetti connected to 4 relays (4 for each window, 8 relays for a 2 door, 16 for a 4-door! Yikes!) - the number of connections needed would be maddening. It would take the better part of the day just to mock up - assuming you knew what you were doing.
                        The next question people ask is "can I steal a module out of a e36/e38/e39 and use that? No. After the e36 BMW added some electronics into the motors that that make in not work with the e30 wiring and motors.
                        • melloh
                          • Sep 2006
                          • 19
                          #102
                          Sorry to revive an old thread, but perhaps my almost old brain can't learn new tricks.
                          I'm trying to emulate the same setup you have (no remote or anything fancy), but I'm confused on which wires connect where.
                          I have 3 green e36 switches and they have 2 different sets of wire colors, none of which match what you posted AFAIK.
                          Also, I seem to have 4 wires while your picture shows 3?
                          If anyone can give me some clarity as to which wires connect to what, that would be greatly appreciated!
                          • melloh
                            • Sep 2006
                            • 19
                            #103
                            So now I'm just talking to myself... But here's where I am and hopefully someone will answer my plea for help.
                            Attempt 1)
                            a) 3 brown ground wires (2 from e30, 1 from e36 switch)
                            b) 2 wires soldered into e36 switch connected to black ground on module
                            c) power wires connected (e30 green/white + module red fused wire + red/gray e36 switch)
                            d) remaining 2 wires connected to soldered module wires (2 pairs, not all 4 together)
                            Result:. Just a clicking sound on module. No window movement.
                            Attempt 2)
                            Same as above, but connected the module's green (motor up) to e30 black/gray and module's blue (motor down) to e30 purple/gray. This wasn't in the instruction, but zooming in on the pictures I saw this.
                            Result: windows up/down only on switch's 2nd click. No 1 touch.
                            Attempt 3)
                            same as above but with the 3 brown grounds connected to module ground + 2 wires soldered on switch. I did this because it wasn't clear to me in the instructions where it says connect brown grounds to ground on module, then it later says connect connect soldered wires to module ground.... So that implies that all 6 go together(?)
                            ​​result: windows go up/down with either 1st or 2nd click on switch. No 1-touch.
                            I also tried other combinations of the modules "-switch down" and so on. No change from attempt 3.
                            Please help!?
