Awesome!! Thanks
True e36 one touch windows DIY
This is a sticky topic.
I didn't say it couldn't be done, I said I wouldn't do it because I 100% believe you wouldn't like it. :) Maybe that's what you meant.
If you really want a "clean look" and only 2 switches, maybe consider hiding the rear switches in the ash tray? Hope that helps.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
Originally posted by gmont02@yahoo.com View PostSo bump?
Yes, see here: http://www.r3vlimited.com/board/showthread.php?t=296371Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
Can this be done with e38/e39 switches? I rather the look of these switches and someone hacked them for use in e30's before but not for one touch, they fit nicely with a little bit of filing. If anyone knows how please let me know. If not I kind of think I may be able to rap my head around this guide and add the module onto it. Resource: https://www.bimmerforums.com/forum/s...One-Switch-Mod
Originally posted by Garrick2007 View PostCan this be done with e38/e39 switches....but not for one touch
Long answer is yes, but not without modifying the switches, and enough wires that would look like a bowl of spaghetti connected to 4 relays (4 for each window, 8 relays for a 2 door, 16 for a 4-door! Yikes!) - the number of connections needed would be maddening. It would take the better part of the day just to mock up - assuming you knew what you were doing.
The next question people ask is "can I steal a module out of a e36/e38/e39 and use that? No. After the e36 BMW added some electronics into the motors that that make in not work with the e30 wiring and motors.Last edited by george graves; 08-17-2017, 03:18 AM.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
Sorry to revive an old thread, but perhaps my almost old brain can't learn new tricks.
I'm trying to emulate the same setup you have (no remote or anything fancy), but I'm confused on which wires connect where.
I have 3 green e36 switches and they have 2 different sets of wire colors, none of which match what you posted AFAIK.
Also, I seem to have 4 wires while your picture shows 3?
If anyone can give me some clarity as to which wires connect to what, that would be greatly appreciated!1 Photo
So now I'm just talking to myself... But here's where I am and hopefully someone will answer my plea for help.
Attempt 1)
a) 3 brown ground wires (2 from e30, 1 from e36 switch)
b) 2 wires soldered into e36 switch connected to black ground on module
c) power wires connected (e30 green/white + module red fused wire + red/gray e36 switch)
d) remaining 2 wires connected to soldered module wires (2 pairs, not all 4 together)
Result:. Just a clicking sound on module. No window movement.
Attempt 2)
Same as above, but connected the module's green (motor up) to e30 black/gray and module's blue (motor down) to e30 purple/gray. This wasn't in the instruction, but zooming in on the pictures I saw this.
Result: windows up/down only on switch's 2nd click. No 1 touch.
Attempt 3)
same as above but with the 3 brown grounds connected to module ground + 2 wires soldered on switch. I did this because it wasn't clear to me in the instructions where it says connect brown grounds to ground on module, then it later says connect connect soldered wires to module ground.... So that implies that all 6 go together(?)
result: windows go up/down with either 1st or 2nd click on switch. No 1-touch.
I also tried other combinations of the modules "-switch down" and so on. No change from attempt 3.
Please help!?
