how to start my car with no key
  • VRSTLE
    • Dec 2010
    • 146
    So i am thinking of buying a 325ix but the owner said he has no keys for the car so i would have to tow it home but the car works perfictly fine(yea im stupid to belive this) he did say that he had a locksmith make keys for the that open the doors but wont start the car. does that make sense for a 89
  • Kvasi
    • Apr 2011
    • 1122
    No. A dealer should be able to fix a key if u bring the documents on the car.
    Id check if its stolen..
    • Asbradley21
      • Jun 2008
      • 1938
      If you need to start the car without a key one way is to take the ignition switch off the back of the ignition lock. You can do this by removing of the steering wheel and the plastic trim around the steering column. Simply pull the switch off the back of the lock and turn it with a screw driver to start. This however does not address the problem of the steering wheel lock.
      S54B32 swap in progress. Status: Getting There
      • JTDay
        • Dec 2009
        • 521
        Did the same shit in my 240 when I broke the key off in the ignition.
        Past: 1987 325iS, Bilsteins - HR Sports
        Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
        2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
        • VRSTLE
          • Dec 2010
          • 146
          hey can i just instal the ignition off of the same car different year and use that key
          • chadthestampede
            • Jul 2008
            • 3600
            spoon
            Originally posted by LJ851
            Feedback
