No BRAKE LIGHTS
  • calvarado4
    • May 2011
    • 1
    No BRAKE LIGHTS
    my brake lights do not work at all when i push the pedal down, I already checked my fuse box and the bulbs, Im thinking that it is something with the brake light switch down by the pedal that has gone bad or a wire of some kind, any ideas?anything helps, thanks
    -carlos
  • bmwguy325is
    • May 2011
    • 1263
    If the brake light switch goes bad the light come on all the time. If you have just removed the stock amp you may have cut the wires to the lights.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • Van Westervelt
      • 9365
      unless the switch becomes unplugged. then they dont come on at all, which can happen as an internal fault too.
      • StereoInstaller1
        GAS
        • 22679
        Carlos, how did you "check" the fuse? You need to test the fuse while it is in the fusebox using a test light. That way you know if there is power to the fuse too.
        Closing SOON!
        Thanks for 10 years of fun!
