Does anyone know where I could get some spacer or adapter to make them fit.
6x9
I used a layer to 1/2" mdf to increase the height of the entire "recessed" front area of the parcel shelf where the speakers mount and applied new carpet. It still wasn't enough clearance for my Infinity Kappa 6x9's, but some tedious trimming with dremel and a carbide burr enlarged the opening in the sheet metal below enough to allow clearance."I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
-Franklin D. RooseveltComment
I'm about to build some spacers out of some spare MDF for my 6.5's in the rear since the PO didn't..
But if you guys wants to be lazy
Here is a 6x9 spacer
Here is a spacer for 5, 6 or 6.5 inch speakers
@dwvw doesn't have to look ugly, only if you let it look ugly. Those prefab spacers I linked will match most speakers and not stand out much. The kick panel speakers in E30's aren't visibly unless you look, and the rears will look fine either way.
Also if you do MDF or whatever you can order enclosure carpet for real cheap and match it to whatever surface the speakers are, then get any number of prefab or make a custom grill, literally make it look better then stock.Different strokes for different folks.Comment
Everything I've seen and read so far seems to indicate that spacers won't give 6X9's enough room to clear the rear deck WITHOUT having to cut some metal. I guess I'll have to measure and figure things out, I'm guessing a carpeted MDF and spacers may work out, or an angled MDF may work, if I find any solutions I'll post here.WTB: Diamond Schwartz HoodComment
I doubled up on the spacers for my Fosgate T1693s. They provided a lot of bass for their size, and the sound wasn't overpowering the front, it sounded balanced. It looked a bit retarded, but eh.
I went to junkyard and found some 6x9's on some spacers, and the metal part of rear deck was intact. It can be done, I guess it just depends on magnet size. Danny thanks for your absolutely pathetic and useless input. Cheers!
I guess beauty is in the eye of the beholder, because I think those things are hideous, we have them in stock at our store. UGLY!I'm about to build some spacers out of some spare MDF for my 6.5's in the rear since the PO didn't..
Also if you do MDF or whatever you can order enclosure carpet for real cheap and match it to whatever surface the speakers are, then get any number of prefab or make a custom grill, literally make it look better then stock.Comment
Yeah, and if all there is beneath them is a tiny hole they will sound like ass anyway. Don't be a waffleswaffleswaffleswaffleswaffles, cut a hole!Comment
