No power to amp
  • Harry's E30
    • 643
    No power to amp
    like title says i am getting no power to my amp, i am in the middle of setting up my lukebox with amp and i have the amp to battery wire, ground and rca cables hooked up what am i missing?
    BUILD-http://www.r3vlimited.com/board/showthread.php?t=242728
  • phenobarb1
    • Jul 2010
    • 105
    You need to connect the line from the headunit to the amp that triggers the amp to turn on. Off the top of my head I can't remember which one it is, but I think it is either blue or blue/white.
    • Harry's E30
      • 643
      thanks, yeah its the rem is it a stock wire?
      • phenobarb1
        • Jul 2010
        • 105
        Well, if your car had the premium sound stereo setup, I suppose you could reuse the line to the factory amp, and then cut off the other end(at the factory amp) and run it to your new amp. I would just run a new line along the same path you ran your RCA's. Are you using an amp install kit? It should come with a remote line. Or, you could just make one out of any 12-16 gauge wire you have lying around.
        • Harry's E30
          • 643
          Ok, i have the premium sound and i also have a remote line from an amp kit but where in the headunit does it go into?
          • phenobarb1
            • Jul 2010
            • 105
            Are you using a factory headunit, or an aftermarket one? If you are using an aftermarket one there should be a simple wiring harness that clips into the back of your headunit. Coming out of this bunch of wires should be a blue/white wire. Connect this to your amp remote line, the blue one that came with your amp install kit, and run it back to your amp and connect the other end of the blue line to the amp where it says REM or something similar.
            Oh, and remember to make sure that the factory amp isn't still being triggered to turn on anymore, s you don't need it now, unless you are using it to power the interior speakers. If you are using it to power your interior speakers currently, I suppose you could just jump you amp trigger line off the old one to the factory amp, and leave everything else in place. Sorry if this is getting confusing, but there are a number of ways to skin this particular cat.
            • Harry's E30
              • 643
              Ok got it thanks a lot for the help and yes its an after market headunit
