EDIT: Read post 2 for a non-shitty update/explanation
Hey, I just picked up a set of premium speakers for my car (front and rear). After plugging them in and doing a test run I cant get them to work! Prior to this I was running factory shitty speakers and they played fine.
I've got a standard pioneer head unit with 50x4 output and independant wires run to all 4 corners. Worked fine before but these premiums refuse to do anything.
The tweaters are working, albiet quite poorly but they are working. The 5-1/4" dont do anything at all. Wiring on the speakers themselves is setup as it came from the factory with the tweets soldered to the second terminal set. What am I doing wrong?? Do these need the factory common ground/amp setup??
