Power Window Goes Up But Not Down
  • offwhiteghost
    • Jan 2010
    • 174
    Got the car with a non working LR window, checked the switches and wasnt them.
    I got a new motor, plugged it in the door with the non-working window before i mounted it but, the window motor will only go in the up direction.
    Any trouble shooting ideas, Im thinking bad ground but where would i check?
    Again, the switches work
    Any help would be great
  • DaveSmed
    • Apr 2007
    • 1407
    With a problem like that %99 of the time its a switch. The other %1 is its mechanical, but you would hear the motor/see the lights in the car dim with the load.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • george graves
      • 20003
      Take the switch apart and clean the contacts, or buy new(used) ones - while you're in there clean the back of the lit up part with a q-tip. It will make them a bit brighter at night. Also, don't spray armor-all on the switches.
      Originally posted by Matt-B
      • offwhiteghost
        • Jan 2010
        • 174
        I swapped the switches with known working switches (Front and Back from other door) not working.
        Im gonna see what voltage in getting in the down position, polarity will be reversed right?
        • StereoInstaller1
          GAS
          • 22679
          not too likely that it is a bad ground.
          It is very likely to be a bad regulator though. The early car regulators have a bad pivot wear issue, when it wears out the gear slips, and that is no bueno on a worm drive...
          Closing SOON!
          Thanks for 10 years of fun!
          • offwhiteghost
            • Jan 2010
            • 174
            Opened up the switch plug and cleaned contacts, working now :D
            Thanks all
            • lostbeachbum
              • 671
              Thanks all
              I did the exact same thing and they work perfectly. Now im waiting on E36 switches to replace them.
              FS:///M-Tech Wallets.
              http://www.r3vlimited.com/board/showthread.php?t=224601
