Avital Champion
  • Mr. Tasty
    • Jul 2011
    • 3421
    Avital Champion
    Hey guys, I have owned my e30 for about 2 months now. While working around under the hood, I noticed an after market siren (sighhhhh). I also noticed my ciggarette lighter light thing was an after market bulb. Also found a switch. Pulled the piece of material from under the steering column to look for a shock sensor/security device. Found this
    The wires were cut from the siren already, so I haven't cut anything. On the actual Avital Champion device, there was a white wire that was not connected to anything, opposite of the other group of wires. I did some research, and obviously this is an old security device. I did not get any FOBs or anything with the buy of the car.
    So basically I don't know what to do from here. I don't want to rip anything out in case it is wired in with a killswitch or anything. Is this system ancient? and should I remove it? OR keep the system, buy some FOBs and program? Any advice would be appreciated.
    Cliffs:
    -Found siren
    -Found other items of aftermarket security device
    -Rip out or keep?
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
  • dogsbark26
    • Nov 2008
    • 533
    What did you find when you Googled Avital Technologies Inc.?
    Looks to me like you should decide if you want an alarm and if this model provides the functionality you desire.
    • Dirtboy
      • 458
      I used to have one of those waaaaay back in the day. It was pretty decent back then, don't know if it would be worth it today...
      Nürburgring info
      • 84driver
        • Aug 2011
        • 234
        Avital is a decent brand, but without the fobs who knows what condition it's in and how long it will last? You could see if you can get old used fobs cheap on ebay, but a new alarm is so cheap I'm not sure it's worth the trouble.
        If there is a killswitch you should be able to see that the ignition line is cut and a relay in-between, similar to this issue. It doesn't look like that model has a built-in killswitch relay, but I would recommend finding a copy of the manual if possible. I bet you can get a PDF from the manufacturer.
        Other than the killswitch a proper aftermarket alarm installation shouldn't break any of the existing circuits -- meaning it's safe to cut and remove. However, if you want to install a new one I would do that at the same time to prevent confusion.
        I love having an alarm on my E30 but I hate mystery wires, so I wish you the best with this project!
        balticblau-metallic '84 318i 5spd 3.91 LSD
        • Mr. Tasty
          • Jul 2011
          • 3421
          okay took all the wires and devices out. Now there is a black thick wire, that was cut in half to go through the device. So both ends of it are not attached, and I try turning it over. nothing. So I am guessing I need to wire the two ends of the black wires together? Is it the power to the ignition?
          (Daily Driver)
          KW V2 Coilovers
          • dogsbark26
            • Nov 2008
            • 533
            Trace that black wire to see where it goes. One end or the other must go somewhere recognizable (ECU, Ignition).
            Or just try shorting it and see if the car starts.
            I too love having an alarm (mainly because I live in a world full of thieves and it allows me a modicum of defense).
            • Dirtboy
              • 458
              I bought my alarm for keyless entry and the blinky light...
              Nürburgring info
              • StereoInstaller1
                GAS
                • 22679
                Black wire is starter, splice it back together.
                Closing SOON!
                Thanks for 10 years of fun!
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  that is what I was looking for thanks man :D
                  (Daily Driver)
                  KW V2 Coilovers
                  • Mr. Tasty
                    • Jul 2011
                    • 3421
                    you should see the pile O' wires and devices. Obviously it wasn't installed by a professional installer. But I am glad all these excess wires are out of my car. I am left with 2 wires, that extend to and almost through the drivers side floor board. Any idea what they could lead too? I know they aren't bmw wires.
                    (Daily Driver)
                    KW V2 Coilovers
                    • StereoInstaller1
                      GAS
                      • 22679
                      chase them to the ends?
                      Closing SOON!
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        I tried, Like I said they go far under the dash and look like they might go through the heat shield.
                        Also there was a group of three wires, that were left alone. They look oem, Red orange and black IIRC, very thin wires. Any clue?
                        (Daily Driver)
                        KW V2 Coilovers
                        • StereoInstaller1
                          GAS
                          • 22679
                          Pics? Details? I can think of several groups like that.
                          And as far as chasing thee wires, just get it done. Chase the damn things until you find them, period. If you have a wire connected to some random bullshit and the wires chafes and gets grounded, who know what could happen?
                          Chase the damn wire.
                          Luke
                          Closing SOON!
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            If the wire was put there by someone else, it can be taken out by you.
                            • dogsbark26
                              • Nov 2008
                              • 533
                              My guess on the two wires would be to that alarm horn you found in the engine bay. What color wires connect to it?
